Question about Canon IXUS V2 Digital Camera
Help! My Canon A75 has the dreaded "E50" memory card error issue. Tried several different cards, can't format cards, can't take pictures, am ready to toss out the window in frustration.....
  • Canon Master
  • 4,738 Answers
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it up a "tiny bit at a time".
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jan 09, 2009
Card write protected is all I can get. tried different cards, the switch on side of card is in unlocked position. what else could help. can't take pictures.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
When i turn my fujifilm z20fd on it says card error, if i try and look at my pictures, it says card error. I can't take any pictures either! Please help!
Well, in this case there is a good chance that there is some problem with your card then.
In some cases, filesystem structure gets corrupt on memory cards, depending on severity you might get variety of issues. In most cases formatting the card solves the problem.
Have you tried to use the card in any other device?
Have you tried to read the card using a card reader?
It might be worth:
a. trying to format the card in camera
b. trying the current card with a different camera (to see if there indeed is a problem with the card
b. trying a different card on your camera
Hope this helps,
Raf
Nov 08, 2009 | Fuji Finepix Z20fd Digital Camera
NO SOFTWAARE CD?
This question comes up several times a day here in the camera section at Fixya. Please don't take the following as a sales pitch as it's not, but please see the following blog article, as it describes the use of an inexpensive card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jul 13, 2009 | Canon PowerShot A75 Digital Camera
Memory Card Error
Memory card error. New card did not help. adjusting notch on side of memory card did not help. What's up? I only took about 100 pictures when this happened. Camera is hardly broke in!
Oct 27, 2008 | Canon PowerShot A540 Digital Camera
Black LCD Screen on the Canon PowerShot A75
There is a service notice for this CCD issue and Canon is repairing this model for free. Give Canon tech support a call and they will send out a shipping label and within 2-3 weeks, you should have a working camera!
Hope this helps!
Jun 08, 2008 | Canon PowerShot A75 Digital Camera
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Card error not error of card?
Scan your card with virus program. Had same problem few weeks ago. 7 Viruses was found on card.
Oct 08, 2007 | Canon PowerShot A75 Digital Camera
Error 50
Do you have any more info? What happened before you got the error? Did the camera suffer an impact?
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Canon IXUS V2 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
