Question about Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X - no picture
Got tv about 03-04, can't find the manual, so don't know troubleshooting or what the remote buttons do. one nite i turned tv on and all there was was thin vertical moving pastel lines, there was sound and i could use the 04 channel on the remote. then after about 30 minutes, the picture was mostly black and then blinked off and on with vertical lines or black with multicolor moving little star like dots. is there something with the remote buttons? or junk tv? or repairable?? i have unplugged it for 24 hours, but nothing changed.
  • 3 more comments
  • light9856 Jan 10, 2009
    Yes, they were across the whole screen, these were not solid lines,they were kind of staticky lines. There was another question/problem posted by someone else that he had taken a picture of his screen but his screen had a solid black area in the middle with the words 'no signal' written. These are the same type of lines that I have.
    yes, the lines are across the entire screen. No the Tv's menu can NOT be seen.
    Checking the boards I'm assuming need to be done by a technical person?? sorry, see obviously I'm not technical or I wouldn't have had to ask these questions.
    I can not fix it or test it myself, so my intent was to find out what might be wrong with it, so I would know whether I would need to find someone to fix it or test it or tell me that it would cost more to fix it than it's worth.
  • Rickyp42w46x Feb 02, 2009
    What does this mean? The sound is working
  • Chuck May 11, 2010
    were the lines over the entire screen?
  • 108 Answers
If the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Posted on Jan 10, 2009
  • Chuck Jan 10, 2009
    Were you trying to repair the set yourself or just trying to see if it was worth fixing or what?
Okay I can see the menu.. but I have a snowy picture. where do I go... I'd like to try to repair myself
Posted on Jan 26, 2010
Need Zenith control code to program universal remote
Three digit universal remote codes for Zenith TV are:
000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153/ 0016/ 0017/ 0092
Four digit codes are:
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Sep 03, 2011 | Zenith P42W46X 42 in. Plasma EDTV
The P42W46X is 6yrs old and has developed 1" wide
It means that the inverter cable needs to be re-seated or replaced.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Aug 21, 2011 | Zenith P42W46X 42 in. Plasma EDTV
Whar channel should be on to play a DVD?
It depends on which input you have the DVD plugged into. The pictures below show the different inputs. One of those should match what you see on the back of your DVD. If you don't know which, you can turn on your DVD player and hit the INPUTS button shown on the picture of the remote control shown below. Or, if it's connected to one of the inputs pointed to by the DIRECT SELECT arrow on the picture of the remote control, you can go there directly from watching the TV. phillip_d971_1.jpgphillip_d971_2.jpg
Apr 12, 2011 | Zenith Z50P3 50 in. Plasma TV
My remote stopped working can it be reset
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
How do i turn the television on i just bought it from the store
Either by your remote or manual. Some models have a master rocker switch close to the ac input where your cord plugs into. That kills all power to the set for vacation purposes.
Sep 28, 2010 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Jul 22, 2008 | Zenith P42W46X 42 in. Plasma EDTV
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Picture is snowy/dark
update: Well, we ended up calling the repair man and we had a bad Y-sustain board and also a bad Z-sustain board. According to the guy who fixed it, it was due to over use of the TV and using main power button instead of shutting off through the cable remote. 650.00 later and a few weeks later, we now have a fixed plasma. No real suggestions on how to get more life out of the new boards.
Sep 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 in. Plasma EDTV Logo
1,359 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
