Question about D-Link DIR-615 Wireless Router
How to block facebook through DLINK 615 router
  • 826 Answers
Login to your DLink router through your web browser. Click the advanced tab.
In the left column, click the Website Filter option. To block sites, enter their website addresses in the space provided (Do not add the http://). Blocking the websites at the router level ensures all traffic leaving your network will be affected by these rules. These include computers, smart phones, gaming consoles and anything else with a web browser.
You can block websites with Dlink router or change the DNS settings in your router and use a service like OpenDNS to block websites.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Nov 23, 2012
SOURCE:
Geekman
  • 32281 Answers
SOURCE: Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on May 19, 2010
  • 34 Answers
SOURCE: on what option do i click on to check or change my
DIR 615 (rev A-C)
1. Click on "Wireless Settings"
2. Click on "Manual Wireless Network Setup"
3. Scroll down and look for "WPA or WPE" for WPE you can change the WEP Key 1-4
4. Scroll Up and click on "Save Settings"
Posted on Jan 02, 2010
  • 85 Answers
SOURCE: dlink dir-615 won't power up. I think maybe it
Have you checked the power supply to see if it is supplying the rated voltage to the plug that plugs into the router. It should be somewhere around 5 - 15 VDC. That's a great place to start. If you have voltage there then repair of the router will require someone with knowledge of testing ICs and soldering.
Posted on Jan 15, 2010
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
  • 81 Answers
SOURCE: How to configure D-Link Wireless Router 615 on LAN ?
The following procedure should get you a connection with any broadband modem that is configured to use DHCP for the router connection, such as cable modems, and many DSL modems. If you require PPPoE configuration for the DSL modem, that will have to be configured to match the ISP requirements.
Note that the wireless encryption and channel selection will have to be done after the basic wired connection is established, the first step is to get wired connections working.
  • Reset the router to factory defaults by holding the reset button down for 15 seconds with power on.
  • Turn off everything, the modem, router, computer.
  • Connect the modem to the router's WAN/Internet port.
  • Connect the computer to one of the router's LAN/Network ports.
  • Turn on the modem, wait for a steady connect light.
  • Turn on the router, wait for two minutes.
  • Boot the computer.
When the computer is completely booted, let's see this.
Hold the Windows key and press R, then type CMD (COMMAND for W98/WME) to open a command prompt:
NOTE: For the items below in red surrounded with < >, see comments below for the actual information content, they are value substitutions from the previous command output!
In the command prompt window that opens, type type the following commands one at a time, followed by the Enter key:
IPCONFIG /ALL
PING <computer_IP_address>
PING <default_gateway_address>
PING <dns_servers>
PING 206.190.60.37
PING yahoo.com
Right click in the command window and choose Select All, then hit Enter to copy the contents to the clipboard.
Paste the results in a message here.
<computer_IP_address> - The IP Address of your computer, obtained from the IPCONFIG command above.
<default_gateway_address> - The IP address of the Default Gateway, obtained from the IPCONFIG command above.
<dns_servers> - The IP address of the first (or only) address for DNS Servers, obtained from the IPCONFIG command above.
Posted on Sep 22, 2009
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
I have Dlink DIR-615 Hardware Version: C2 Firmware Version: 3.01 and want to upgrade firmware as it hangs when i use my Samsung Tab2 over wifi...
The new firmware is available with instructions at Dlink's Website.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
This is the english address for the support on your model of router.
Feb 01, 2013 | D-Link DIR-615 Wireless Router
My instruction manual is in Chinese, i am using a mac and i cannot connect wirelessly to the internet, I have a DIR-605 router.
well here is a link to obtain the manual http://www.dlink.com/products/?pid=DIR-615
you need to select Support Resources Tab and choose the revision type you have. then you select product manual. One example is this one "DIR-615 no rev. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | D-Link DIR-615 Wireless Router
How do I reinstall a dlink 615 modem. mcafee syys a trojan has been identified each time I try the install disc. can I install without the disc and how?
I can help you with your DLink DIR-615 router problem.
You don't really need to run anything from the disc to install a router - there is no setup program on the dlink cd you are required to run. Routers operate independently of the computers they are plugged into.
The most useful thing on that disc is the user manual, which you can download direct from DLink here. Any other bits and pieces that are on the 'installation CD' are also available from their webpage.
I hope that helps.
Aug 28, 2010 | D-Link DIR-615 Wireless Router
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
Dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Jan 04, 2010 | NetGear DGN2000-100NAS Router
How do i reset my DIR-615 SO I can make a new password?
To reset the DLink back to the factory defaults - power up the DLink and press and hold the RESET button until the LEDs flash.
You can then reconfigure the wireless router with new settings.
Dec 28, 2009 | D-Link DIR-615 Wireless Router
D-Link DIR-615 Wireless Router Logo
2,695 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
