Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Can not reset tv
I turned the set off the other day with the front on/off switch. This morning, I tried to power up the set and even after trying to use the system reset, un-plugging the set, and trying everything I could, the set would not power up. I unplugged the power and waited the customery five seconds, used both the remote and or power switch. When the system reset is pushed, the gree light in front blinks rapidely, but it goes out after that. I have had this happen before. I saw some possible solutions to this problem in other postings.
    Novelist:
  • 192 Answers
These sets have a common problem with the front panel buttons sticking and not allowing the set to turn on. Unplugging the control panel and using the remote to turn the set on normally diagnoses that problem (If you try this, remember that once the set is origionally plugged in, it takes about a minute and half before the set can be turned back on. Another problem could be in the convergence circuit. If you hit the power button and the indicator light comes on and shuts off then that is the circuit that is most suspect. The -24 volt line fusible link as well as the 24 volt line will open up if the convergence IC shorts out. There is a way to diagnose this set by pushing in and holding the menu and device button on the set at the same time until the indicator light starts flashing. There are two sets of flashes, such as, 2 flashes and then 3 flashes. Hope this helps.
Posted on Jun 03, 2007
The tv was working find and i turned the tv off friday night. the next morning it would not come on I checked the power and made sure it was plugged in. why would it work ok one day and not come on th
Did you try turning it on by the button on the tv or with the remote? If you only tried with the remote check the batteries, maybe replace them. Try the switch on the tv, if that doesn't work I don't know. By any chance do you have any pets?
Sep 16, 2014 | Computers & Internet
Panasonic TH-P50X50Z tv has no power after turning off mains switch then turning back on again
ive had this issue many times since buying my same model tv..i leave unplugged for 3-4 days..plug bk in and usually sweet to go again..
Nov 24, 2012 | Televison & Video
Grundig TV turns itself on
Remove power for a day and see if the processor resets. It seems to be only due to the timer as the TV can be triggered only from the internal timer to power ON.Try and reset all the timer settings , switch power off completely and it must cancel all settings.
Dec 12, 2011 | Televison & Video
42" Panasonic Plasma does not turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 15, 2010 | Panasonic TH-42PX60U Television
Projection TV flickering blue screen, cannot access devices
Did you ever get this problem solved. I am having the exact same problem?
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred...
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Nov 08, 2009 | Toshiba 36A43 36" TV
I have A Pioneer SDT50W1 rear projection TV which is about 11 years old. It is in A1 condition but recently I have had a problem when turning on the set. When I press the on off switch on the front of the...
The most likey cause of this is poor solder connections either in the power suply area or the convergence circuit area. If you can solder and are comfortable working inside the set where there are potetially dangerous high voltages (even when unplugged), you maight be able to resolve this yourself. Try resoldering any connections on the boards that appear grainy or have rings. Update this with your results.
Thanks,
Dan
Feb 18, 2009 | Pioneer Televison & Video
Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Feb 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
SONY KV32-FQ70U BLINK ERROR
Try unplugging the TV for about 10 minutes and then tunung it on again. Try a factory
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
I'm assuming step 2 means hold down the power button.
Nov 27, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
