Question about Whirlpool LER5636P Electric Dryer
I have a maytag dryer and had the belt replaced 2 months ago and paid $180.00 AND AGAIN TODAY 1/8/09 IT IS DOING THE SAME THING. THE DRUM IS NOT TURNING??????WHAT IS THIS? AND WHAT CAN I DO????"?"
    Scholar:
  • 58 Answers
It depends ont wo things how big of a load are your drying. And is the idler pulley ok? If you are overloading the unit yes you will wear the belt in no time flat. But when your belt was replace the first time did the tech take a look at the idler pulley?, if that's worn it will also take out the belt in no time flat. all i can recommend is contact your service provider tell them your issue and hope they can maybe run a recall or get you a new belt under a part warrenty. good luck
Posted on Jan 09, 2009
Maytag LDE412 Drum Roller keeps breaking
perhaps your dryer vent pipe is plugged with lint and causing the inner parts to overheat .
Feb 15, 2016 | Maytag Dryers
Why does the belt keep breaking on my dryer model dvlr223ee2ww?
perhaps bad bearings either in the drum supports or the tensioner pulley .
Aug 30, 2015 | Dryers
Won't Spin Drum
The problem could be a list of things . Let's start checking the belt , it coul be that the belt is broken or something is keeping it from doing its job ( a piece of clothing coul be stuck) due to the burned rubber smell you detected. It coul also be the electrical door switch and After checking the three first steps then comes the motor part lets hope is not . Good luck
Nov 20, 2013 | Maytag Centennial Series MEDC300XW
Had a service call 7 months ago on 16 year old Maytag Stack w/d to lubricate drum roller that was squeaking. Squeak has returned. Any pointers on lubricating it myself, or is it worth replacing the drum...
Lubricating the bearings is usually only a temporary "quike fix".
Replace the bearings,and lubricate the bearing shafts with a lithium grease.
Mar 04, 2010 | Maytag Dryers
Dryer is scraping as it turns. Is there a belt that is worn? Started doing it after 3rd load. Did the same last time we used it.
The dryer drum is suspended between the front panel and the back panel by extrusions that protrude into the front and rear of the drum. There are thick felt pads attached to the protrusions that support the drum and isolate the metal of the drum from the metal of the front and rear panel protrusions, allowing the drum to rotate freely. A large belt encircles the drum and a pulley attached to a motor mounted under the drum. A spring "thing" applies tension to the belt to prevent the belt from slipping. If the noise is a metal on metal sound, check the condition of the felts. Other causes of noise have been stretched belt slipping on drum, weak spring "thing" not keeping belt tight, motor bearings dry (oil) or worn (replace motor), and pulley on spring "thing needs lube (lube). Hope this helps.
Jan 12, 2010 | Maytag Dryers
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Jan 06, 2008 | Maytag Legacy Series Top Load Washer
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
