Question about GE JASRM24912 Remote Control
How do i use my ge jc012 universal remote
I just need to know how to program my emerson tv with this remote
  • GizmoDuck Feb 21, 2009
    I need the code for a symphonic tv.....I lost the manual moving :-(
  • 50 Answers
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Posted on Nov 18, 2007
  • 3 Answers
SOURCE: universal remote
Codes for Panasonic TV.....171,148,054,170,062,374,381,437,003,070. You can Goggle the programming info...Just ask...How do I program a GE Universal Remote... There are about 7 steps...easy if these codes work....good luck...I have a remote that none of the given codes are working........
Posted on Nov 29, 2007
  • 360 Answers
SOURCE: GE Universal Remote - Have codes, not working
you will need to manually find the codes with a code search. If you do not have the owners manual, let me know, I will attempt to find it for you and post a link. Let me know
Please take the time to rate this solution.
clarkco
Posted on Feb 17, 2009
SOURCE: PROGRAMING MY GE UNIVERSAL REMOTE RC24912-e 5811
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
Posted on Mar 17, 2009
johncaman
  • 201 Answers
SOURCE: I HAVE A G.E. UNIVERSAL REMOTE CONTROL. #24912 I
Hi, try this first:
1. Manually turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the SETUP button
until the red indicator stays on, then
release the SETUP button.
3. Press and quickly release the desired
device button (TV, VCR, etc.). The
red indicator blinks off once.
4. Press the ON•OFF button
repeatedly (up to 300 times) until
the device to be controlled turns
off. The red indicator blinks off with
each button press.
Most users will store VCR codes under the VCR
button, Cable codes under CABLE, etc. If (for
example) you want to store a VCR code under
CABLE, first follow the procedure for Direct Code
Entry (previous page) and press CABLE in step 2
of Direct Code Entry, then enter ANY VCR code in
step 3 of Direct Code Entry. Then follow the steps
above for Code Search.
Note: Code Search starts from the currently
stored four digit number under that mode.
Sometimes the first code that “works” with your
device may only allow limited functionality (e.g.
the MENU button might not work). There may be
a code that performs more functions. Continue the
code search process until the best code is found.
5. Press and release ENTER to install the code.
Otherwise, you'll have to do manual code entry, here are the possible Emerson codes:
EMERSON ................ 0004 0009 0044
................. 0135 0049 0051 0189 0053
................. 0147 0039 0130 0227 0233
....... 0250 0252 0254 0257 0265 0266
....... 0310 0325 0456 0040 0041 0042
....... 0021 0023 0024 0179 0045 0025
....... 0027 0030 0032 0034 0035 0037
Here's the manual code entry instructions:
1. Press and hold the SETUP button until
the red indicator stays on, then release
the SETUP button.
2. Press and release the desired device
button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
3. Enter the 4 digit code
from the code tables
(on separate sheet).
Note: after a valid
code entry, the red
indicator turns off. For
an invalid code, the
red indicator flashes.
4. With your device on, press ON•OFF.
If the device turns off, no further
programming is required. Note: If
some buttons do not operate your
equipment, try one of the other
codes for your brand
Hope this helps, please rate :)
Posted on Mar 22, 2009
Need code list for Emerson TV
Kathlene, Check the attached links,instruction and guides Emerson TV codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-emerson-tvs
https://www.remotecodelist.com/remotes/emerson/emerson.html
What is the remote code for an Emerson TV
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Jun 08, 2016 | Emerson Televison & Video
I have a GE JC024 tv remote and need code for an Emerson tv
These are the setup codes for Emerson TV, with GE remote control.
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Sep 20, 2012 | GE Remote Original Jc024 Remote Control...
Jumbo remote control wont program
if u still have the manual to it---- look at the top right corner of page 11.. there are separate codes for for emerson tv's listed as---
TV VCR/DVD
036 041
39 027
155 002
198 008
231 u could try these---
good luck.
Feb 13, 2009 | GE RM24912 Universal Remote Control
Need codes to the remote for a Sharp TV.
look under remote manuals rca, radioshack, it will lists for tvs vcr ect.
Dec 17, 2008 | Gemini 1 Device Universal Television...
Universal remote codes
here are some codes that might work 0456-0004-0009-0044-0135-0049 the first one might be it if you don't know how to set it here's how press setup and hold it until the light stays on then press t.v. and then the code. hope this helps
Oct 19, 2008 | Emerson EWF2004 20" TV
Programming tv
I have a ge universal remote and a sanyo tv i lost the paper of codes that came with the remote
Aug 20, 2008 | GE JASRM24912 Remote Control
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
Program a ge universal remote to an emerson 12" tv
i have a ge RM24911 universal remote but i need the codes
Apr 15, 2008 | GE RM24912 Universal Remote Control
I have an emerson tv and a GE universal remote
as this was posted to the rca rcu300 remote location and not in a ge section, i am undure of what model your remote is. that being said, you can find a list of all codes the ge remotes support and how to program them by clicking here.
i hope this helps, if not, please post the model of the remote control, and the emerson dvd/tv combo.
hope this helps,
trin
Nov 16, 2007 | RCA RCU300 Remote Control
Universal Remote Code
for my emerson the universal code is 189.
Nov 12, 2006 | Emerson TS1997 19" TV
GE JASRM24912 Remote Control Logo
3,225 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
