Question about Whirlpool Duet GHW9150P Front Load Washer
Top loading washer will not drain
It tries to spin but of course it has water in it and it just makes a noise.
thank you!
  • Bill Dozier May 11, 2010
    what kinda of noise does it sound like
  • 530 Answers
Is this a whirlpool, kitchenaid, kenmore? If it is any of these you probably have a broken drive coupler. Tip the washer back and lean against the wall. DO NOT TIP ALL THE WAY OVER! It will missalign the tub. So you have to take the pump off next the motor. you will see clips just push them up and the bottom one down I use a flat screw driver. you will need to take the 1/4" socket and remove the screws on the motor beforre you can take the clips off. Remember ONLY DO THIS WITH THE POWER TURNED OFF. Ok. So now you can drop the motor you will see the drive coupler the part number is 285753a
Posted on Jan 11, 2009
Washer not draining
sounds like you need to replace the pump
Aug 30, 2017 | Whirlpool Washing Machines
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
Washer making loud noise willnot spin cycle or drain water
heatman101
Aug 10, 2011 | Electrolux AWF 1435 Front Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin or agitate
hi, Does the water drain out in the spin cycle? Sounds like the coupler might be bad. Is this a top load machine? Asking questions so I can be clear and give you better info on your question.
Please let me know.
Thanks
Vic
May 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Makes a hard banging noise when the washer is draining and spinning
Check the springs, and make sure the water ring still has water in it.
Jun 23, 2008 | Roper RAX4232KQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
