Question about Sony KP-51HW40 51" Rear Projection Television
Sony Kp-51hw40 my big screen turn on real go picture. but after about 2 mins. it starts to turn a blue color and then fades all together no picture only sound what could be the problem
    President:
  • 3,130 Answers
Sounds like a bad solder connection in the sweep power supply. Not a repair for the novice I'm afraid. If you get it fixed before the set goes out completely, it should not be that expensive of a repair. Good Luck
Posted on Jun 04, 2007
  • Larry  Dillon
    Larry Dillon Jun 04, 2007
    A slight possibility that the blue tube could be going bad as well.
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Sony Trinitron screen flashing
The picture tube is starting to fail. The increased screen voltage allows it to stabilize at the expense of color quality. Sorry to say, but it is time for a replacement.
Dan
Dec 17, 2009 | Sony Televison & Video
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
No picture
I had a similar problem and got a TV repair man to fix it for real cheap. The whole fixing took less then 30 min and he goes to your house to fix the TV. He fixed it for an excellent price that left us astonished. He lives in NY. Email me if anyone needs his contact information. You wont be disappointed.
Mar 19, 2009 | Polaroid FLM-1911 19 in. LCD Television
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Sony KP-51HW40 51" Rear Projection Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
