Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fault 52 can you tell me please what is fault 52 on a fisher & paykel washing machine
  • zuchreformer Jan 25, 2009
    Zref . I hav ethe same error code 52 but if you set the washer to spin manually it seems to complete the cycle?
    Habit-Forming:
  • Fisher and P... Expert
  • 108 Answers
Code 52 is a loss of water during recirculation cycle. Possibly due to a faulty divertor valve. Check to see if water is circulating back into bowl & no water escaping out of the drain hose. May also be caused by a faulty motor controller.
Posted on Jan 19, 2009
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
Wash machine will not turn on
Hi just read your posting.Could you please reply and tell me the model number of your machine.The reason for this is that some models of Fisher and Paykel machines do not turn on because the drain pump is faulty but most of the time when the machine does not turn on the problem is your Motor Controller.Please reply with additional information and I am sure I can help you rectify this fault.
Jul 28, 2010 | Fisher and Paykel Washing Machines
Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Just wondering where I could get a pdf version of the Smart Drive MW 058 5.5 kg washing machine manual, please?
i have a service manual for that machine. do you need a uses manual or service manual? if you need a service manual please tell me what the fault is maybe i can help. if you need a user manual try ringing your fisher and paykel dealer in your area.
May 27, 2010 | Fisher and Paykel Washing Machines
My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Jan 24, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher and paykel washing machine
If you can indicate which lights are displayed when the machine is beeping,that gives one the fault code to be able to tell what the fault is!!
Jun 28, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Help
PCB or lid lock Regards Engineer
Jul 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
694 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
