Question about Panasonic TC-26LX60 26 in. LCD Television
Blinking Power Light
I tried turning on my T.V. with the remote. The screen did not power up, and it remained the same black as if it were off (not the AV black screen). Instead, the small red light labeled "POWER" in the bottom left hand corner of the unit blinked on and off. I tried pushing the power button on the top of the unit, but nothing. So I unplugged it from it's power source and plugged it back in. Still I was met with the same problem.
  • Jason Purnell Jun 04, 2007
    Thanks for your input. Literally right after I typed this problem, I went in and hit the power button and the thing turned on like normal. I guess it needed a minute to work itself out.
  • 934 Answers
With just those set of symptoms - and nothing more - my first guess is that the power supply (PS) board has a problem. It is possible to replace the entire board, but it is also possible that the board could be repaired. The PS is not an inexpensive item so my best advice would be to have a professional look at it and estimate the problem. Then discuss the options repair/replace... Bill
Posted on Jun 04, 2007
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
I try to turn on the TV and the power light keep blinking but it doesn't turn on, the screen remain black...
The set has a problem that is likely power related===consider having a shop or a tech look at it---cannot wish it away, someone will have to open and check things to even have a chance to fix this.
Dec 03, 2012 | LG 37LG30 37 in. LCD HDTV
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Screen remains black and power indicator light keeps blinking. We have tried to turn it off but nothing happens. It has been this way for over 4 hours.
whats the model number of the tv? is it a continuous blinking pattern or just blinking? sometimes the blinking light is an error message that you can search on google and find out what is wrong - give me more info and i can help you.
thanks,
michael
Feb 21, 2011 | Samsung Televison & Video
Screen remains locked on Blue background welcome screen when it finally comes up. Status light remains blinking green. Over the past 7-10 days it took several tries powering on then off before picture...
Tv manual PCB control buttons all work?Like power on/off,volume - + and chanels + - all work than it not the manual PCB board control IR is parts of this board.Not the IR problems,when tv is finally on the remote work fully everything buttons?No,could be remote control have problems.Tv might have DM power supply board problems.
Feb 08, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
My Hitachi P50x01au plasma TV screen goes blank suddently, and the power indicator green light blinking. TV cannot be turn off by the remote. I switched off the power manually, and turn it on, but the...
I would open back and check all boards for cracks, this is a problem with these sets.Then count the blinks on the set and see if it stops for a moment and starts back.
Jan 19, 2011 | Hitachi Televison & Video
The screen remains black when i turn it on. The power button turns green and blinking but the screen remains black.
try using the Fn + F?key (has a graphic of a monitor)F5 or F7 to switch the system from external monitor to the laptop ... you probably have it in presentation mode for external monitor.
Oct 14, 2009 | Acer Computers & Internet
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
T.V. problems
broken screen, how much to fix panasonic th-42pd6ou
Oct 16, 2007 | Televison & Video
Panasonic TC-26LX60 26 in. LCD Television Logo
186 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
