Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Your Feedback Hi tborn6: Thank you so much for your feedback. I have a couple of questions for clarity. I have the freezer portion of the refrigerator set on the warmest setting which is 1. The coolest setting is 5. Should I move the setting up to 2, which means the freezer will be cooler? The control on the meat and vegetable tray is a lever that runs parrallel with the refrigerator. The front portion of the setting is for the vegetable tray and has and an arrow facing towards you and then one dot. The back portion of the setting is for the meat tray and it has an arrow facing away from you and then 4 dots. The same lever is used for both trays. Where should I place the lever to set is as you described? I have turned the humidity all the way to high. I appreciate so much your feedback. I hope that it will work so my vegetables and meat will stop freezing up. The actual model of my refrigerator is 57022 I believe. Thank you. Jacqui
  • 700 Answers
The settings that you said sound correct, you do not want your vegetables to dry out and shriviel up. The meat compartment should be running around 31-33 degress to keep the meat fresh, basically that is the ideal situition for you. Do you store allot of ice cream ? thats the only thing that needs to be extremely cold (-10) degrees. Best to keep in a deep freezer not the one inside.the only thing that I use mine for inside is ice and food that is going to be ae real quickly. long term storage is best in a deep freezer that you have to manually defrost. That way it neveer freezer burns the food. Hope this helps out.
Posted on Jan 09, 2009
Freezer and refrigerator not cold enough
turn up the thermostat,
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The bottom freezer portion works, but the top portion is not cooling at all.
Check the refrigerator coil to see if it is iced over. If so you will have to defrost the coil. Also make sure the fan for the evaporator is working. This should fix your problem. Please leave feedback. Thank you
Aug 24, 2010 | Amana ABB1927DE Bottom Freezer...
What are the factory suggested settings?
Half way between off and the coldest setting on the t-stat.
Your refrigerator should be from 36f-40f and the freezer should be around 5f-10f. I hope this helps you. Please leave feedback.
Thank you.
Aug 24, 2010 | LG 24.7 Cu. Ft. Side-by-Side Refrigerator...
I have a lot of frost in the freezer and the bottom half is warm the fan is working in the freezer but it not pushing it down
Make sure the door is closing all the way. Also check the door gasket for rips. It sounds like warm air may be getting in.
Thank you.
Aug 24, 2010 | Frigidaire FRT17G4B Top Freezer...
My freezer is cold but the refrigerator is hot what wrong. I have a ge refrigerators models gts22jcp.
Sounds like you have a dirty condenser. It's located under the frig. Clean all the dust and dirt out so air can circulate. After this is done the unit should cool down.
I hope this helps. Please leave feedback.
Thank you.
Aug 24, 2010 | GE Refrigerators
Its freezer is not freezing ice quickly or surface of freezer are not filled from top to bottom
Hello
A common solution to this problem is to clean the condenser coil underneath or in the back of the refrigerator. This will help get rid of the heat and help pull down the temp inside the freezer.
I hope this helps you. Please feedback.
Thank you.
Aug 24, 2010 | Refrigerators
Refrigerator is not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 25, 2010 | Frigidaire FRS26R4A Side by Side...
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
128 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
