Question about Refrigerators
Icemaker the water will not stop running once the tray is filled. do i need a new icemaker and if so can you point me in the right direction to buy one. I have an Amana sqd26vw. thanks very much
    Scholar:
  • 67 Answers
Heya,
It sounds like you need a new float for your Ice Machine, there are not that expensive. There are alot of good ice machines out there, just make sure that you get one that you like the look off.
Amana are good units thou.
Let me know how you go
Posted on Jan 09, 2009
Water does not stop pouring from water/ice dispenser. Door-to-door GE Profile Refrigerator Model TFX22PPDACC. How to troubleshoot the problem? Or what part need to be replaced?
With the water running tube/pipe is cracked in between or its got loose from its fitting.First inspect the line for this problem.The tube from which water passes, one end is connected to the water valve at the back base of refrigerator.And then from valve two tube runs.One tube is for water dispenser and another tube is for ice chamber filling.Follow that tube from back of the refrigerator.The water dispenser tube That passes through the freezer door also.And the ice maker tube.That connects to the back of ice maker tray.The water fills in the tray.See if that tube is got loose and its not throwing water out instead of ice maker tray.Many a times this happens.--- May be you need to remove the ice maker to get exact location for tube setting and position.----------- But if tubes from water and ice dispenser sections are fitted properly and then there can be crack in the tube.------------But if tubes checked out ok then other possibility can be faulty water fill grommet.------- The grommet is cracked.And that is causing the leak.--------- Go to the back of the unit and remove the cover at the lower right of the unit. This is where the water line goes into your unit. Remove the water line at the solinoid that goes to your ice maker . This will allow you enough slack to remove the old water fill tube and replace it with the new one.
You need to push the white retainers in to release the tubeing from the solenoids.
The part you need is called fill tube grommet.It has to be removed and replaced.The tube is connected to the grommet. Click this link below for more help:---http://technoanswers.blogspot.com/2011/06/how-to-remove-ice-maker-fill-tube-from.html
------------ The other possibility for this leak, is water valve.The water valve close and open.When its open, it lets water to the tube.When it closes it stops water.But if the valve is not closing then it will let the water to enter non stop, slowly --- slowly the inside tube getw over filled and then starts leaking.------------ The water valve is not required as per the problem.But if after doing all the repairing, still the same problem, noticed then water valve is required.Because is water valve is not closing properly, then it leaks some water, (drop by drop) and this can cause water to collect in the grommet and this gets formed into ice and the same leaking repeats.---------but at present dont buy water valve.Just keep an eye on this same problem.sometimes leaking will start after few days.In that case also replace water vale.------- Now for other parts, that are extension hose,icemaker tube and clamp.Out of this you will require clamps, sometimes while removing old tube the clamp gets cracked.you can buy this.The extension hose is required if the tube is getting short or actual hose is cracked in between.i dont think you will require extension hose at present.And for ice maker tube.This tube can also be cracked and cause leak.this tubes by time gets bit swollen and loose its grip.Its actually not required.But if you still replace it, that it will be good.--------so you can order clamp and icemaker tube with the grommet part.----------- The parts which you want to order, this is direct link for parts:-- 1. Dual Inlet Water Valve------------ (http://www.partselect.com/PS901314-GE-WR57X10051-Dual-Inlet-Water-Valve.htm)
2. Icemaker Water Line ----------
(http://www.partselect.com/PS299643-GE-WR2X9245-Icemaker-Water-Line.htm)
3. Icemaker Fill Hose Extension ----------
(http://www.partselect.com/PS298725-GE-WR2X7927-Icemaker-Fill-Hose-Extension.htm)
A fill tube clamp for the fill tube grommet----------------
(http://www.partselect.com/PS297951-GE-WR2X4754-Fill-Tube-Clamp.htm) ----------- This will help.Thanks.Helpmech.
Jun 16, 2011 | Refrigerators
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
Ice tray dont empty and water keeps running out
Something caught inside the water valve (replace water valve ) such as dirt , sand . Or , the icemaker died in the fill position . Disconnect the icemaker plug inside the freezer , and see if water still runs from the icemaker fill tube . Also make sure the icemaker fill cup on the icemaker , is not clogged with ice .
Sep 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
Dec 07, 2008 | Refrigerators
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
