Question about Dual LHT1000 System
Speakers wont work
UNIT POWERS UP ..BASE WORKS..BUT I CANT GET SPEAKERS TO WORK..ANY SUGGESTIONS..TY
  • dryfly708 Jan 09, 2009
    the system is brand new ..ive tryed 3 speakers ..no sound
    New Friend:
  • 111 Answers
CAN YOU SEPARATE THE SPEAKER FROM THE SYSTEM .IF CAN CHECK IT WITH MULTIMETER OHM SCALE OR USE 1.5V DRY CELL AND CONNECT IT TO SPEAKER FOR VERY SHORT TIME I MEAN CONNECT AND HOLD ONE WIRE TO BATTERY AND TOUCH OTHER WIRE AND CHECK IF ITIS SOUNDS .IF YES PROBLEM WITH YOUR AMPLIFIRE UNIT.CAN YOU OPEN IT.I CAN HELP YOU.
Posted on Jan 09, 2009
Speakers quit working-but tryed in another unit n they work--work great on -headphones still-very baffled
There should be a speaker selector switch of button on the front of the receiver, make sure that you have selected one or both of the speaker possibilities.
Mar 19, 2014 | Sharp Audio Players & Recorders
Panasonic KX-TG6700
Did you try disonnecting the unit from the power for a few hours?
Apr 13, 2008 | Panasonic KX-TG6500 Cordless Phone
My Pioneer DEH-P3500 car stereo is having problems. The front panel buttons will not work at all... the radio was working, but the head unit would not let me change stations or make any adjustments. I...
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
Jun 21, 2011 | Pioneer DEH-P3500 CD Player
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
We have 3indoor/outdoor speakers for deck-they are static
I would suggest moving them close to the base unit (if you havent already) to see if that improves the sound quality. If so, then you know you have some kind of interference in the area. Also, what output are you using from the BOSE? If you are using a headphone output or other variable output, you may be overloading the input circuit of the wireless base unit. Try turning down the volume on the BOSE or connecting to a different output.
Aug 19, 2009 | Cables Unlimited Audio Unlimited 900MHz...
Code f61
the f61 code is an audio code for panasonic first make sure all connections are correct and tight for spearkes...at the base if unit has base and with connections in back of unit and are fully in to connection terminal...make sure speakers are on and not on mute ...sometimes though you may have to re strip the wires to get into connection termianl in the back of the unit if that does not work call panasonic 1-800-211-PANA(7262) for more technical support
May 15, 2009 | Panasonic Audio Players & Recorders
My built in speakers are not workin in hp dv6000, even after downloading the drivers nd installing it i have the same problem . . But my headphones are working properly . . Speakers are provided by altec...
Based on the number of recurring problems in this area, with this unit and these speakers, which precisely replicate your problem, which results from fusing of the speaker connections due to excessive heat toward the junction of the base of the unit and the screen (input power, power to to the screen, et al) and thanks to your full disclosure of the problem and your efforts to solve it, one can only conclude that the speakers are the culprit and the only possible non-cost solution is return for warrantee work if available.
The chipset employed if other than Intel produces more heat which is exhausted in the same area as the speakers. The speakers are certainly quality speakers, but are subjected to excessive abuse by the design.
Mar 28, 2009 | Foxconn 661M03-G-6EL Motherboard
Cant use old packard bell speakers
No . The reason that you cannot is that they are amplified type speakers and the amplifier section appears, based upon what you stated, to be in the old monitor.                      Sorry.
Feb 15, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Subwoofer works - sound goes away after some time
POSSIBLY A BREAK IN THE SPEAKER SUPPLY LEADS TO THE ACTUAL BASE UNIT
WE HAD THIS AND IT WAS NOT THE SPEAKER BUT THE BOLT ON CONNECTION UNDER THE SPADE TERMINAL ON THE BACK OF THE BASS UNIT
Dec 16, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
Dual LHT1000 System Logo
106 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
