Question about Toshiba Satellite Computers & Internet
Toshiba satellite a105 clicking noise near power supply
My laptop turned off while in use and will not turn on again. There is a very faint clicking sound near the power supply. The hard drive still works, I tired a different power adapter and works fine, took it apart and blew out the dust in the fan. It still will not booth up, no lights or anything but this clicking sound. I took the whole thing apart and still can hear the clicking sound when its plugged in.
  • Toshiba Master
  • 17,605 Answers
When you say that the hard drive works I have to ask how you know. There are not many parts in a laptop that would make a clicking noise. One of them is the hard drive. Is there any display activity at all? Lights on the unit that come on?
Posted on Jul 24, 2017
harvester3
  • 181 Answers
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Posted on Feb 09, 2008
SOURCE: no power and there is a clicking noise in ac power adapter
Any news on this? I have exactly the same issue this morning.
Posted on Jul 14, 2008
  • 3 Answers
SOURCE: Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Posted on Aug 16, 2008
  • 97 Answers
SOURCE: Toshiba Satellite S1730 Power Problem
Ideas only...
Maybe the problem of your laptop is the mainboard
Posted on Sep 22, 2008
  • 338 Answers
SOURCE: My laptop(Toshiba Satellite A105 - S2051) wont turn on
hi, this is tricky, as the machine does seem to freeze even before booting. the fan may have become stuck, use some compressed air with the fan inlet (bicycle pump may do) to clean out some dust.
wait some time and switch on again.
observe if the green lamps for harddrive and cd-drive light up.
if no, the computer does not boot up, it may be then that :
the fan is broke and laptop prevents overheat damage by not booting up(buy a new fan and replace it)
or the machine itself is broke
in either way, if the solution i provided did not help, i would recommend to see a technician!
good luck then
Posted on Aug 08, 2009
Intermitently, my screen goes dark, but the
1.)It could be your video card
2.) Yes it is expensive for a laptop
3.)I would first check your screen setting for turning off display...
If you are using vista:
-Right click on your desktop then choose personalize
-Then click screensaver
-On bottom click on "change power settings..."
- On the left click on "choose when to turn off the display"
Your monitor can turn off without your computer being in sleep mode.
Dec 26, 2009 | Toshiba Satellite A105-S4334 Notebook
The laptop just went dead. Does not power up off
check the pins on the adaptor connector that goes into the laptop socket....
they all must align correctly....
normaly it will have three pins, even if one is bent or mis-aligned it will not work....use a small screwdriver to slighly adjust the pins to the aprox correct postion...use a mignifying glass to have a look into the pins....
Dec 17, 2009 | Toshiba Satellite A105-S1712 Notebook
Toshiba Satellite A105-S4048 problem with AC Adapter When I turn the laptop on with the AC adapter, after checking the BIOS freezes and does not boot Windows. If I turn the laptop in only with battery boot...
There's not much you can do. The problem is definately with your motherboard. I'd recommend a bios update, but normally you can ONLY run a bios update if the battery and the ac are both plugged in.
This problem is pretty common among Toshiba's A105 and P105 models.
Besides replacing the motherboard there's not much you can do.
Sorry.
Mar 10, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite A105-S1013 no power
Try taking out the battery pack and using power supply only. If it boots, turn off laptop and try with battery again. If works, great, if not your battery my be faulty and you'll need a new one.
Jul 31, 2008 | Toshiba Satellite A105 Notebook
Computer will not boot up
if it doesn't do anything you either have a dead battery or a fried hard drive or your screen is broken, does it make any noise when you power on? try recharging it, that happen to me one time on my field (****) laptop i pulled the battery out waited 10 secs then put it back in hope that works
Jul 14, 2008 | Toshiba Satellite A105 Notebook
Satellite A105-S1014 unexpectedly turns off.
First u have to open it and dust then if problem continiuing then you have problem with power suply or ram memorie!!!
Oct 15, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
