Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
The picture is intermittent, stays for a long time,
The audio is OK but the picture goes off some times, sometimes even after 2 days.we have to smack it at the back for picture to come back. Loos like a lose connection.How to open te back cover?
  • 51 Answers
Is the backlight staying lit even with the picture out? I had the same problem with my Aquos LC32DA5U my backlight was always on but no picture at all, just a lit up black screen, the problem is the LCD controller, I replaced that and it's perfect now.
Posted on Jan 16, 2009
Samsung LN46E30; audio goes loud intermittently.
check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 09, 2016 | Samsung Televison & Video
Sony KDF-E60A20 HDTV
there seem to be a ic which is getting back and will soon balck out the tv.
Jun 26, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Mitsubishi WS-65611 losing HD signal
Not to worry.Its really a Great tv...But...the only thing you should do to fix this just get it hd ready and your and dont get it integrated with an hd receiver and everything will be fine!
Oct 11, 2007 | Mitsubishi WS-65611 65" Rear Projection...
How to fix my Samsung tv ..picture goes in and out intermittently
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
Feb 25, 2016 | Samsung Televison & Video
My LG LRH-880 HDD/DVD recorder sometimes stops recording by itself, before the end of the programming and even if there is enough disk space left.
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
Sep 13, 2008 | LG Televison & Video
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
May 04, 2017 | RCA 36V430T 36" TV
The bottom half of the picture goes black intermittently. sometimes it resolves itselt, sometimes you have to smack it
that you have to " smack it " could mean that a cold solder joint on the board proberly out of the vertercial output. To test, while the TV is on use a long plastic or wood tool and push on the board. Sometimes you may have "resolder" EVERY joint, ground, wire connection in that circuit.
Jun 14, 2008 | Philips Televison & Video
Picture on DSR704 gets 'blocky', loose audio at the same time
Check the satellite signal strength on different transponders. On mine, 16 ands 17 are intermittent as are a number in the 20s but only on satellite 2 (even if you switch the cables). It's probably a bad 2nd tuner.
The only fix I've found is to repeat the "guided setup" and tell it you have only one cable coming in. That will take tuner2 out of the loop.
Oct 25, 2007 | Philips DSR704
Picture on tv
check for a bad solder at the the tuner section or within the tuner . Bad solder ground within the tuner can cause this fault
Apr 21, 2007 | Panasonic CT-36D32 36" TV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
266 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
