Question about Grilling
Safely Turning Off a Microwave.
How do you safely turn off LG MS3446VRL microwave? Do you just unplug it straight away? I used to do that with my previous microwave and it broke down in less than a year. So what should I do to safely turn it off?
  • 21 Answers
Just open the door. There is nothing unsafe in opening the door while it is running.
Posted on Jan 13, 2009
Instruction manual for lg microwave ms3446vrl
Your manual can be downloaded free here:
LG Support Search Results LG AU
Feel free to contact me through my site if you need more help:
http://www.microwavecontrol.com/
Oct 25, 2016 | LG Microwave Ovens
I have a brand new pannasonic microwave and when we turned it on it sounds like somthing is catching the fan? Does it have safty bolts in the back that need removing first ( bit like a washing machine)?
no it may sound like a wire is catching the fan when its turned on PLEASE BE SAFE WHEN OPENING! when or if you open the microwave make sure that its unplugged first and that its safely unable to turn on inside try moving the wires away from the fan and place the cover back on safely and make sure its snug and tight back to as it was otherwise it may leak some radio waves out into the house i've rarely seen a few times where the wire catches the fan and opened em up to move the cord away also make sure the fan moves freely
May 26, 2014 | Washing Machines
Lg.ms3446vrl,nor warming food
The magnetron does the warming. It may have failed. You also could have a failed door interlock
Sep 29, 2013 | LG 1.5 Cu. Ft. Mid-Size Microwave
My LG (model ms3446vrl) wont heat anything. Everything else works fine. It is only 2 weeks out of warranty too, not happy. Lynda
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 04, 2011 | LG LMV1680ST Microwave Oven
I covered the plate with 'heavy duty aluminum foil' thinking it was safe for for microwave use, then I saw a sparkle inside while turning. I stopped it, took off the aluminum cover, turned the microwave...
The food is safe as long as the food has not got oxidized aluminium on it.
Microwave energy is very high and will melt metals!
As long as it is not arcing any more there should be no problem.
Jan 03, 2011 | LG Microwave Ovens
Turn table stop turning and wont heat
Your oven has a couple of switches inside that are operated by the door latches. One of them controls the power to the turntable and magnetron tube power transformer. The switch is either out of adjustment (which can happen if the oven door gets closed real hard) or is bad. I would suggest letting a professional check the oven and repair the problem. Door repairs have a direct effect on microwave leakage and it's better to have them done safely.
Dec 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
LG Microwave oven Tried to remove the countertop light bulb. Glass came off metal base still in unit. How do I remove the base, ist screw type bulb?
try using a small potato,push it into the base while turning the potato.it may lock onto the base and unscrew it....UNPLUG IT FIRST...
Nov 16, 2010 | LG LMV1630ST Microwave Oven
Light under microwave does not work. turned on heard loud pop?
Hello :
It must be an overheated lamp . You need to replace it . I think you still can use your Microwave safely if it works . If it doesn't work , then contact again please !
good luck .
please rate .
Mar 28, 2010 | Kenmore 80402 Microwave Oven
LG microwave oven
As long as the waveguide itself isn't damaged, you should be able to replace the shield without issue... That shield only prevents food from splashing onto the waveguide itself and is not part of the microwave RF protection... Check your local hardware store for touch up paint.. shouldn't matter what brand as long as it contains rust inhibitors.. Good luck...
Aug 22, 2008 | LG Microwave Ovens
Grilling Logo
56 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
