Question about Maytag Performa PAV2200
SHUTING DOWN DURING WATTER DRAIN
I HAVE 2 UNPLUG AND REPLUG MABEY SEVERALL TIMES 2 GET IT 2 DRAIN AND ITS MAKING A LOT OF NOISE WILE DRAINING
  • Anonymous Jan 12, 2009
    my washer will fill up with water just about half way then stop. If we unplug and then replug it works.
  • 640 Answers
Defective pump..but replace pump and belt at the same time,,,onthejob
Posted on Jan 24, 2009
My samsung front end loader goes out of balance during the spin cycle. Is not making any noise. Flashes an "nd" code.
as far as I am aware the ND code means not draining would check your drain hose pipe or the filter could be blocked causing it not to drain properly while spinning
Oct 15, 2017 | Samsung Washing Machines
Washer is making a grinding noise during the draining cycle and is not draining fully.
Hi Connie, The problem your describing is most likely the water pump. They have an impeller(encased propeller) that creates the force to drain the water out of the machine and if it breaks it would be very noisy and the washer would not drain. I hope this helps you out and good luck !
Mar 09, 2015 | Washing Machines
The problem is engine vibration during start and shut down only
I think the catalytic converter ceramic matrix brick is broken up and that is the source of the vibration and noise.d
Nov 04, 2012 | 2004 GMC Envoy
My LG air conditioner is spitting out water and making a weird noise....i took off the front panel and theres a lot of water in what i guess is a condensation pan....ive tried drying the little bit i can...
Go around the back side and unplug the drain hole! These are designed to drain out the back through a hole in the drain pan. Maybe your unit is tipping forward and not draining like it should. You can use a coat hanger or wire or even a shop vac to remove debris from the drain.
Aug 15, 2011 | LG Electronic Window Air Conditioner
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Front load washer ~ 1 year old started making noise during the draining cycle
Access the drain pump and clean out whatever is in there. Front load machines need the drain pump cleaned on a regular basis.
Aug 18, 2009 | Frigidaire Washing Machines
Dishwasher not draining and making a noise
Ok, normally, when you hear abnormal noises and the draining has stopped, this will point to the pump/motor assembly. this assembly , basically, runs together in unison. the pump/motor are as one and if the motor is malfunctioning, the pump will not drain properly. this noise is coming from the pump housing. There are many parts that are located in this housing and one fragile part that can cause issues is the Impeller. this piece provides the pump action that moves the water during drainage. If the sleeve that connects to the Impeller becomes stripped, the motor drive bolt will simple spin freely, causing this noise and no drainage. The motors fine but, you will have to replace the pump assembly in order for this noise to stop and the normal draining cycle to return. just to be safe, check all the drainage hoses as well.
please rate and god bless:)
Apr 01, 2009 | Frigidaire Dishwashers
Sounds like something stuck in the washing machine when draining
Something has become stuck in the drain pump.
1. Remove the back cover. The drain pump is in the lower left corner.
2. Tilt machine forward for easier access.
3. Unplug the pump motor power plug.
4. Loosen the hose clamp from the tub.
5. Remove the drain hose connection from the pump.
6. Remove the three screws securing the pump to the tub.
7. Remove debris from pump.
8. Replace pump.
9. Merry Christmas...
Dec 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Sound During Drain
Yes, you can pull one of the pump's leads to find whether the noise comes from the pump. You should unplug machine's power cable first and be sure that the disconnected wire is isolated. Before replacing the pump look that it clean from any foreign object/ Good luck!
Aug 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Neptune washer makes horrible noise - now won't drain
Does the washer make noise while the drum is spinning? Or, is making noise when the drain pump comes on? If the drum is spinning and making a lot of noise the rear bearings are usually bad. They cannot be removed from the drum, however. The entire outer tub shell has to be replaced, because the bearings are molded into the plastic. If it's only making noise when the drain pump comes on during the drain cycle, your drain pump may be obstructed in some way, or the pump itself could be bad. Getting inside the machine to check either component is not easy, because the door has to be removed, along with the front panel, rubber door seal, and top of the machine. Sorry, this may not be an easy fix for you. But, I hope I can lead you in the right direction. Let me know if you need further guidance.
May 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
