Question about Panasonic Room Air Conditioner CWXC104HU
Air conditioner split panasonic, wireless control
The wireless control doesn't activate the air, how can i do it manually?
  • puafran Nov 14, 2010
    air doesn't blow very strong. why
5 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Posted on Dec 31, 2007
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
  • 145 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
SOURCE: Westpoint split air conditoner remote contol unit
I want to locate a Eolia West Point A/C remote
Posted on Oct 23, 2008
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Where can i get panasonil CS-YS24RYK operating manual ?
http://www.retrevo.com/samples/Panasonic-Air-Conditioner-manuals.html
May 03, 2015 | Panasonic Single Split Wall Mounted Air...
Panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
• Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes. • Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Frigidaire wiring diagrams
The only manual method mentioned is for testing or emergency purposes only. Sorry.
Jul 27, 2014 | Frigidaire FRS093LS1 Ductless Split Air...
What is the little black bar that comes out of the vent by temp . Control and why doesn't the temp go under 60
is this unit a split system or a window rattler?? im guessing it is a window unit and the black bar you refer to is the thermostat sensor?
May 21, 2012 | Panasonic Heating & Cooling
Looking for Panasonic split air conditioner manual download
Click on this link to find your manual:
http://www.panasonic.com/CONSUMER_ELECTRONICS/bp_split_ac/support.asp
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | Panasonic Heating & Cooling
Panasonic split systems
Try here =>
http://www.partstore.com/Search/Model/Matsushita/Panasonic.aspx?
Dec 30, 2008 | GE Quiet-Aire Ductless Split System Air...
Dear,
Thank you!
Lee Lee
Oct 19, 2008 | Heating & Cooling
Panasonic Room Air Conditioner CWXC104HU Logo
233 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
