Question about Panasonic PV-V4612 VHS VCR
Elevator Wheel ?
Can't find the Elevator wheel, I believe its at the front. I'm new to all this, but would like to try. I'm trying to fix a jamed tape. Thankyou. Gary
  • 883 Answers
Look for a small motor that performs this action. then spin the motor shaft
Posted on Jun 03, 2007
Front wheel doesn't spin freely and squeaks on 2n'd day i got it.
Hi James:
If New, I'd take it back to the dealer.
If used.....
Set bike on jack so front wheel is raised. Make sure it is secure so can't fall.
1) Remove front brake pads........... spin wheel If it still squeaks, remove wheel and service bearings.
If no squeak when brakes removed, service brakes.
Jan 18, 2016 | Motorcycles
I have a 1994 Ford Bronco Xlt with a 302 V8 Automatic.. When the truck was on a lift the front passenger side wheel had alot of negative camber I believe.. The wheel was slanted like this \ . The stearing...
To check the joints jack the wheel off the ground by the lower control arm and putting one hand on the top of the wheel and the other on the bottom try moving the wheel in and out. If you can then one or both ball joints are bad. Have someone move the wheel and watch the joints you will see if one or both are bad. While the wheel is off the ground move the wheel from side to side, that will tell you if you have bad steering linkage. You don't have to hold the steering wheel straight when changing the joints. But you will need an alignment when your done. Note; When installing the new parts try to get them as close to up and down as you can. Also if you change the tie-rods count the turns and install the new tie-rods to the same turns.
Apr 12, 2013 | Cars & Trucks
When i drive at 100 kph my stering is shaking.why?
Hi James,the problem could be one or more of your wheels,,especially the front ones,could be unbalanced.If not,then one or more of the steering linkage members could be worn.To establish the latter,jack up one of the front wheels at a time and try rocking the wheel by holding it side ways looking for play.For the former,you'll just have to take the wheels to a shop that has a wheel balancing equipment.Good luck buddy.
Jan 16, 2013 | 2007 Toyota Hilux 2.7
Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
Dec 18, 2011 | Toys
Rear wheel is broken need replacement
I believe they carry them at Sears, since many of the Sears mowers use the high wheels. Tractor Supply also has a pretty large selection of mower wheels. Best of luck to you.
James
Aug 25, 2011 | Mtd 22" White Outdoor Self Propelled High...
The ignition key cylinder in my 2003 suburban is stripped or stuck and won't allow the key to turn. What can I do to fix it?
the stering wheel has 2 come off 2 get cylinder out need a wheel puller has 1 screw that has 2 come out under wheel then cylender comes out try moving the wheel when trying to turn it it gets jamed some times wiggle the wheel back and forth and turn key same time
Apr 04, 2011 | 2003 Chevrolet Suburban
My steering wheel is locked, and i just cant unlock it. everything is jamed
use some elbow grease to pull and push the wheel whilst operating the key
Jan 03, 2011 | Mercedes-Benz C-Class Cars & Trucks
Phil and Teds Sport, front wheel shudder
you can phone Out n About 01234 344230 email: info@outnabout.com they are the importers for phil n ted or try www.buggypitstop.co.uk they service and repair Phil n Ted
Mar 01, 2009 | Regal Lager Phil & Teds Sport Buggy Single...
Tape stuck inside. child put it in upside down.
Take the top of your VCR off keeping mind of where the screws came from, by the front of the tape there will be a gear wheel called the elevator wheel. After you have carefully unlooped the tape from the head, turn the elevator wheel, and you will be able to remove the tape then. Simply spool the tape back up and replace the cover.
http://www.fixya.com/support/t931883-tape_stuck_in_vcr
Aug 16, 2008 | Televison & Video
Tape stuck in vcr
Panasonic PV-V4612 VHS VCR Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
