Question about Honeywell Programmable Thermostat Heater
WHERE TO CONECT THE 2 WIRES TO THE NEW THERMOSTAT
I HAV 2 WIRES THAT WAS CONNECTED TO OLD UNIT THAT CONTROLS A GAS HEATER.
WHERE SHOULD I CONNECT THESE 2 WIRES ON THE NEW UNIT?
  • 61 Answers
Connect one to Red, R or Rh.
Connect the other to White or W.
Posted on Jan 09, 2009
I have williams model 5009622 , my furnuce come on not stop , i think thermostat bad , i changed the new one but not kick on , i conect 2 wires then it kick on , you think that may be bad thermopile is...
Make sure to purchase a thermostat that will operate on a millivolt system the old Honeywell t-87 would work but the new T-87 replacement ones do not work. make sure the wires are not touching each other at the connection points. Hope this helps.
Jul 04, 2014 | Williams (5009622) Ceramic Gas Wall...
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
W and W2 wiring on old thermostat...where do they go on the new thermostat?
It depends on the equipment you are connecting the thermostat to. If you have a heat pump, the thermostat must be wired differently than if you have separate heating and cooling equipment. If you have a two-stage or modulating furnace (or boiler), the w and w2 wires will conect for heating, and the y and g wires will connect to the air conditioner. Naturally, some configuring must be done with the new thermostat so that it acts correctly. w-w2-wiring-old-thermostat-go-new-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
please mark this answer helpful.
Feb 22, 2013 | Honeywell RTH6400D 5-1-1-Day Programmable...
My old thermostat had 4 wires connected to it, I have 5 wires white black ,blue,yellow and red. the wasn't connected to the old thermostat.Do i need to connect the red one to the new thermostat because...
locate the wires at the unit and hook them up in the same way . If it was not hooked up before you most likely don't need to hook it up now.. but check the unit where the wires connect to it.. let me know Have fun
Jul 24, 2011 | Heating & Cooling
I am replacing an old Lennox thermostat with a new Lux DMH110 digital thermostat. My furnace(oil) has only two wires on the thermostat(heat only). I connected the wires according to directions of new...
Make sure on the furnace that you have the same colored wires connected at the thermostat to R and W. Check for good connections at both locations. You can always test to make sure the unit fires by crossing the two wires together. If the unit fires, you have a bad thermostat.
Feb 17, 2010 | Honeywell Programmable Thermostat Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Williams wall non-elec gas heater. Black copper wire tagged thermostat?
First make sure this is a heater set up for a remote mounted thermostat. If so, the gas valve has 3 screws labeled TH (thermostat) and TP (thermopile) that's the flame sensor with 2 wires coming off it, I don't know where the goofy name comes from. there will be one screw that has both, usually the top one. Wire accordingly. The new valves have a solenoid on the bottom. this connects to the high temp. sensor up top. It has 2 wires on it, one connects to the thermostat wire, the other goes to the screw with TH and TP. Or you can skip it and connect the wire from the back of the valve to the Th and TP screw. Make sure the thermostat wires aren't pinched somewhere, thus eliminating the thermostats control.
Feb 23, 2008 | Heating & Cooling
Heating & Cooling Logo
152 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
