05 cherokee thank you very much for the pinout you gaveme, i believe this will help, although there are four plugs in the pcm module, i was wondering which one you are showing me, i searched the shop manual but it seems to be lacking pinouts and the info i require. if you know that would be great, thank you again for taking the time to send that info, i really apreciate it and it is exactly what im looking for seein as how im sure theres no proper signal behind the speedo, too bad there isnt
  • 379 Answers
Hi , the schematic is way too large , i see the pcm , i can't distinguish 4 connectors , the only clue i think i can give you is the color dark green and brown , if you look at the last set of wire colors i think you will have to find them in one of the four connectors and you will have it , i only show one of each color at the pcm , heres 2 more pix , im showing were each wire ends up . like i say this is over my head with the navigation hook up , but i hope you comprehend the pix .
im trying to show in relation to each end of those 3 wires , the begining and the end of each wire with no interuptions or splices in the middle of any of them . hope thats good for ya , cheers .
Posted on Jan 09, 2009
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Dec 05, 2015 | 2001 Cadillac DeVille
Where can I get a pcm pinout
Most mechanics get that from dealer mechanic on his computer. I have gotten them several times over the years and it costs nothing.
May 23, 2014 | 1998 Chevrolet Venture
I need the PCM or ECM pinout for a 97 jeep grand cherokee
did you try the FSM. its there, why not read the FSM.
the wiring
then pdf page 178'
and double posted. please only post 1, time or update 1 post, 1 question.
Mar 13, 2014 | 1997 Jeep Grand Cherokee
Pinout for 05 F150 5.4
Here are the pin out diagram for Ford OBD2 PCM
Or go to this link
Aug 24, 2012 | 2004 Ford F150
Where is the pcm located on a 2000 jeep cherokee
The PCM is located in the engine compartment next to the air cleaner assembly. If you need some diagram, juyst contact us in the previous link.
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 25, 2011 | 2000 Jeep Grand Cherokee
1997 jeep cherokee sport. No heat coming through the defrost
Hello and welcome to FixYa!
I'm suspecting that it's not a fuse issue. It's more like a PCM (power train control module) issue. If the PCM is faulty something will surely fail. First to consider is to replace the PCM if that's the case, but before proceeding please try this trick. Remove the positive battery connector and let it sit for at least 5mins. or more before reconnecting it. This will reset the system and can get your vehicle back to it's normal operation.
If the problem still persists then go for the PCM replacement. I believe you'll be good after the replacement.
Hope this helps and thank you for using FixYa! Have a good one!
Sep 18, 2011 | Jeep Cherokee Cars & Trucks
Were is the pcm located in my 2002 jeep gand cherekee larodo
The Powertrain Control Module (PCM) is located in the engine compartment. The PCM is referred to as
JTEC (Jeep/Truck Engine Controller), exactly on the passenger side of the firewall, aft of the coolant reservoir. You will have to remove the reservoir. The PCM is a square metal box mounted vertically to the firewall with three bolts. On the front, you will find three large rectangular connectors, one black, one white, one gray. Beneath the two outer connectors, you will find the two screws. You do not need to remove the connectors.
Hope this helps (remember to rate this free answer).
Jun 02, 2011 | 2002 Jeep Grand Cherokee
2000 Jeep Grand Cherokee V8 Car will suddenly stall, fuel gauge down and won't start. Wait for about 1 hour or more, sometime less, fuel gauge comes on and engine starts. replace P0117, plugs, fuel...
I'm suspecting that the PCM (power train control module) is faulty. If the PCM is faulty the electrical fails at any given time. The PCM is like a car's brain, I strongly suggest that you have it replaced as a first course of action.
May 03, 2011 | 2000 Jeep Grand Cherokee
I have a jeep cherokee and an engine light is on the fault code i am getting is p1265 any one help please
P1265 = glow plug #3 control circuit low.
Looks like a problem with your #3 glow plug,either the glow plug itself or the GP driver in the PCM.
This would explain the starting good one time then hard the next. I would test the glow plug if it is good there may be a problem in the PCM (power trans control module). Are you getting any other fault codes this would point to a bad PCM.
Hope this helps (remember comment and rated this) TY for using Fixya.
Apr 07, 2010 | 2005 Jeep Grand Cherokee
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
