Question about Microsoft Xbox 360 Console
Xbox 360 AV Cable Error E 74
So I was playing GTAIV on my 360 just fine for about 30 minutes. I shut off the console and about 10 minutes later started it up again. However, I noticed some messed up graphics so I decided to restart the console. But when I did that, the lower right quadrant of my ring of light started flashing red and I got an error on my screen "System failure" in many different languages. Down at the bottom - E 74. I looked up E74 and found many different issues with it. However, this error only occurs when my HDMI cable is plugged into my machine. When I take it out it starts fine. Also, whenever I slightly shake my console, there is a small shaking, like a burnt out lightbulb, near the AV cable input. What could be the problem and possible fixes? (Besides sending it to Microsoft for repairs). Thanks in advance.
  • cosmosis08 Jan 09, 2009
    Sorry, I forgot to mention that I have tried 2 seperate HDMI cables. Both of them have caused the error.
    Problem Solver:
  • 10 Answers
Hey cosmosis08, this error specifically means a bad A/V cable. Try using a different HDMI cable :)
Hope this helps, Robert
Posted on Jan 09, 2009
  • Robert Widdick
    Robert Widdick Jan 09, 2009
    And just thought that I'd add a statement that I forgot in the solution #1 -- if replacing the A/V cable doesn't work, it is an internal problem, and regretfully, you'll have to call Microsoft. -Rob
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
My xbox has the error code e 74 what can i do.
This is a problem with the AV cable and its output. Try cleaning the AV cable and its socket. If the error persists, try another AV cable that you know is fine. If that doesn't solve the problem, then it's the scaler chip near the AV port - the HANA or ANA chip. In that case, you'll have to call MS Support to get your console repaired or replaced.
Jan 09, 2011 | Microsoft Xbox 360 White Console
My xbox 360 comes up with an error 74 code how can
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
If your still under warrenty send it to microsoft, if not you could try the towel trick (i dont recommend) or bring it to someone that can repair it for you (try cr@igs list)..
Mar 08, 2010 | Microsoft Xbox 360 Console
My 360 received an error code 74 what does this mean and how can i fix the problem without sending my 360 in for repair
4TH LIGHT ON ERROR CODE 74 SYNC CODE 1022
Things DONE;
replaced AV cable
cleaned contacts
WHAT NOW !
Dec 22, 2009 | Microsoft Xbox 360 Console
E 74 error message on my xbox 360
thats because that error message means your AV cable has died or the chip inside has cooked, if the error goes away wen you remove the cable its the cable you need to purchase a new one
Oct 26, 2009 | Microsoft Xbox 360 Console
Turned on xbox 360 got a black screen saying system error and E 74 at the bottom of the screen and theres 1 red light on bottom right of power button
Mar 06, 2009 | Microsoft Xbox 360 Console
E 74
the e74 error is one of two thing the av cable might be damaged or the gu chip inside the xbox has become faulty from overheating of misshandling of the xbox in transit the chip is on the the mother bord in the middle just above the main cpu one sure thing is that the picture will go eventually if the av cable in not faulty the best thing is to get it right back to microsoft if its under wananty or wait intill it dies then send it bk to microsoft under the 3 rrod fault becuse once the picture has gone there is no way they can check if it has ever had the 3rrod as there is no picture , xbox now give 3 years of warnatey on the 3rrod so get it back to them .
Feb 01, 2009 | Microsoft Xbox 360 Console
Console
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
Feb 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74
Try the cable swap if that works then great buy yourself a new cable and bam your set if that doesnt work then you need to contact MS or use a replacement plan. cuz your GPU is fried.
Dec 27, 2007 | Microsoft Xbox 360 Console
1 red light: Error E 74
try the x-clamp fix, also try a different av cable as yours can be damaged
Oct 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
154 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
