Question about Apple iPod nano
No icon on display
When I switch on my ipod I can see no icon or menu to select only white screen.can you tell me what I need so I can operate my ipod?
Thank you.
    Problem Solver:
  • 9 Answers
Your screen might be dead you could try replaceing it. (eBay about $12)
Posted on Jan 09, 2009
My ipod does nothing just shows a sad face
The "sad" iPod icon usually indicated that the iPod is having trouble connecting with a computer. This is, in most cases, not a serious issue and can be resolved with a few easy procedures. In most cases the data on the iPod is intact, even if the sad icon was displayed.
Verify the iPod has a charge. If in doubt, allow it to charge for 30 to 60 minutes. Do not remove charging cable. Toggle the Hold switch to the Hold position and back. Then press both the center (Select) button and the Menu (upper part of wheel) for up to 10 seconds. Release the Select and Menu buttons when the Apple logo appears, and quickly simultaneously press the Select and Play/Pause (bottom of the wheel) button. Switch from the electrical plug to a computer connection (if necessary) when the Disk Mode screen appears. The screen should change to the normal "Do Not Disconnect" update screen. Contact Apple about finding a repair service if the iPod will not go into Disk Mode.
Feb 03, 2013 | Apple iPod Audio Players & Recorders
White screen otherwise no display
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thanks!
Jun 02, 2011 | Apple iPod nano
Hi this has a blank white screen, clicker sounds, but no menu etc. Did sync (displayed do not disconnect etc), but now gone to all white again! Thanks
Welcome to Fixya
1st option:
Thanks
Feb 24, 2011 | Apple iPod nano
I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
Apr 29, 2010 | Audio Players & Recorders
White screen on my silver 120gb ipod classic
The white screen on Apple Products is never really a good thing.
You've probably heard of the blue screen of death(Windows) and the red ring of death(XBox), the white screen is referred to the white screen of death, normally not something you can recover from.
But try this anyway:
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Aug 15, 2009 | Apple iPod nano
Language change
Hi, Let me provide you the steps to change the lnaguage on your ipod mini...
OR
Feb 21, 2009 | Apple iPod MA446LL/A MP3 Player
Apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 05, 2008 | Apple iPod nano
Frozen Ipod Nano
  1. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  3. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  4. Connect it to your computer.
  5. In iTunes, select Restore to Restore the iPod firmware. This erase everything on the iPod.
Dec 04, 2007 | Apple iPod nano
My ipod was hang!
ya just hold the menu and center button till an apple image appears on screen!
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
26 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
