Question about Dell E173FP 17" LCD Monitor
Pop up auto adjust in prograss
My lcd facing always prompt auto adjust when i start the pc.need help
  • Anonymous Feb 07, 2009
    Saem thing here.
    Problem Solver:
  • 10 Answers
I had the same problem with my HP LCD. I'll turn on the monitor and it will run auto adjust and set everything to the max making the screen very bright. What I did was remove the button panel board and put it back. Everything works fine since then.
Posted on Mar 19, 2009
Install driver for LCD Screen, or Monitor
Posted on Mar 01, 2009
When your computer is first starting up, it is using the most basic video drivers available. The logo screen for your computer probably shows up, and than eventually goes to windows. If it is auto adjusting at startup, it is because of the very low resolution of the boot menu. It should automatically revert to your normal resolution when windows starts up. It's perfectly normal for it to do thos.
Posted on Feb 12, 2009
Auto adjustment in progress keeps popping up
Try turning down the brightness on the monitor, sometimes this will fix the issue, if not the problem is in the inverter board and needs a professional to assess it further.
Mar 10, 2012 | HP w1907 LCD Monitor
How to install swat 4
Follow these instruction that will be help you -
1. Insert CD 1 into your CD/DVD drive.
  • 2. Wait for the auto-start feature to bring up the installation menu. Once the menu pops up, click on the "Install" option.
  • 3. Enter the serial number included with the game when prompted to do so.
  • 4. Place CD 2 in the drive when you are prompted to do so by the installation program, then click "Continue."
  • 5. Once installation is complete, you might be prompted to install DirectX 9.0c. If prompted, follow the installation procedure listed in the window.
  • Apr 26, 2011 | Computers & Internet
    I have compaq tft8020, from last 2 days i m facing problem. lcd is showing automatic"adjustment" between cable 1 or cable 2 with in 1 second.pc display is showing, but adjustment is continusely showing and...
    mr farhanpk, When very strange stuff starts to appear on the screen of any older model ccfl -back-lit lcd display I would certainly suspect and investigate the monitors ac to dc internal power supply for BAD, SWOLLEN, LEAKY electrolytic filter capacitors. Check your pc with a "known-good" monitor to make certain it is not the pc causing the problem. 12fixlouie
    Aug 07, 2010 | Compaq TFT8020 18.1" LCD Monitor
    Auto Adjust keeps popping up
    Is this a computer moniter or a tuner/tv
    Aug 02, 2009 | BenQ FP71G 17" LCD Monitor
    Auto adjustment in progress popping up and
    Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
    Jun 09, 2009 | HP w1907 LCD Monitor
    The auto adjust has started popping up/picture keeps moving
    take your monitor backand Req a new one.
    It is having a "jumper" prob ,... The solder is arcing from one diode to the next.
    Dec 23, 2008 | Neovo F-417 17" LCD Monitor
    Auto adjust
    i have had the same prob with a pl1700 would like an answer also
    Jul 21, 2008 | Planar PL1700 17" Flat Panel LCD Monitor
    CANON PIXMA IP1200 resetting
    My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
    Please Help Me...
    rakibfuture
    Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Always says: Auto Image Adjust
    These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
    Sep 24, 2007 | ViewSonic VA703B LCD Monitor
    Dell E173FP 17" LCD Monitor Logo
    727 people viewed this question
    Alun Cox
