Question about RCA 36V430T 36" TV
Tv shut down and I found the HOT to be shorted.
Installed replacement transistor and nothing. There are no ps voltages with the exception of 163vdc on the gate of the mosfet. I have checked for solder joint problems and all electrolytic caps check out ok. There are no shorted diodes in the circuit and no visible damage such as arching etc. I am working without a schematic so any help is greatly appreciated.
  • 1 more comment
  • psbrennan Jan 10, 2009
    Thanks 'Tech 1819'
    I ordered a flyback today and hopefully we will see the light in a couple of days-
  • psbrennan Jan 23, 2009
    Well, I installed the replacement Flyback and the power LED lit for a couple of seconds and then the HOT started buzzing. It has shorted again. Anything else I should look for before putting in another transistor?
  • psbrennan Jan 25, 2009
    The Transistor is definatly shorted across all three legs. I have not found anything else that is shorted or terribly out of tolerance. I took the HOT out of circuit and the power supply is running ok. Any other thoughts?
    Thanks--
  • 108 Answers
This set is famous for defective flybacks. part number is 262342. replace the flyback
Posted on Jan 09, 2009
  • Chuck Jan 10, 2009
    cool, keep me posted..
  • Chuck Jan 24, 2009
    remove the HOT and check the resistance between the base, collector and emitter. Do this with the transistor out of circuit.
UndefinedI've checked a Panasonic crt color tv model TC-21fj20p, and I find a hard way to discover the cause of the problem until now.. The set has a good primary voltage supply. No problem with the IC...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Any short circuit at the horizontal output section circuit will shut down all the secondary SMPS voltages, as there is short circuit protection circuit to all Sony TVs.
Oct 28, 2014 | Televison & Video
Turn tv on, tv screen will come on blue then turn off
Hi
I think your TV set has a short circuit in the RGB output circuit and shuts down or mute to protect the CRT. This circuit is located in small board attached to the CRt neck. If you are keen on electronics or you have a fried that is, you can mesure the voltages in the collectors of the three big transistor mounted on that board. The voltages of these transistor collectors are slightly diferent and the faulty one has low or even no voltage. It should be replaced.
Sully
Sep 28, 2013 | Televison & Video
Tv not switching on just makin noise from power supply & hissing @ the flyback transformer with horizontal becoming extremly hot then afew min later horizontal burns out(D1398)
If the horizontal transistor getting shorted, this could happen.
Check the transistor 2 SD1398. If found faulty replace it.
But replace black colored doides in the circuit as a whole.
Leaky diodes can not be determined easily with the multi meter.
Especialy the small high voltage diode near the small transformer
connected to the 2 SD1368 transistor.
Sep 03, 2010 | Televison & Video
Dead set, HOT transistor keeps shorting
It's the copper coiled magnet on the neck of the crt closest to the front of the tube.
Dec 21, 2008 | RCA 36V430T 36" TV
Denon AVR-3105 Unit tries to come on but after a few seconds power LED flashes red. (Unit shuts down) I found transistors Q1015L and Q1035L in the output circuit shorted. However, replacing these...
Look for open resistors in the same area. Also, if the transistors that you replaced are the output transistors, you should replace their compliments as well. I don't have the service manual with me at the moment, so I'm juist giving you generalities. If you can, lift the center pin of the output transistors and measure (and post) the voltage readings on each of three pads for each transistor. That should give me enough info to guide you further.
Thanks,
Dan
Oct 07, 2008 | Denon Audio Players & Recorders
No picture ,No sound except high pitch shriek from transformer/JW14140
check your power supply board,higher voltage than the normal voltage coming out to your power supply,replace the oscillator that control your regulator.
Sep 25, 2008 | GE 31GT740 31" TV
My TV
the old ticking sound... yes.. it means your power supply shut down and continously trys to reboot ... hense the tick sound as the voltage rises and fails.
Means you got a short somewhere. Most likely the obvious high power consuming High Voltage Suppy... and as I found in 99.9 percent the Horizontal power Transistor shorted... 80 percent Flyback, 10 percent audio... 10 percent some odd circuits like vertical or yoke as shorted.
you have a short.
Sep 10, 2008 | Sanyo DS24424 24" TV
Philips 27PT6442/37 power
Sounds like you have a short in your power supply load. Probably the high voltage transformer and/or horizontal output transistor. Stargazer P.S. I've found that a lot of the newer sets are prone to high voltage transformer failure.
Aug 11, 2007 | Philips Magnavox 27MS343S 27" TV
Tv problem
The F27442 uses the CTC203 series chassis and that symptom is very common. If the horizontal output is shorted you MUST resolder the coil in series with the base of that transistor and the pins of the small horizontal drive transformer. When they have been properly resoldered you can put in a new original horizontal output transistor. If the output transistor shorts out again then your flyback (high voltage) transformer is shorted and needs to be replaced.
Aug 08, 2007 | RCA F27442 27" TV
Toshiba CF3566A Tac 9190
the cuestion is if every time it shut down you have the hot shorted,or not. have measure the flyback/yoke/Hot working current? it must be under 0.6Amp ,if is greater something is wrong and cause overheating.Normally I touch with my fingers to "measure" the temperature. and what about the Micro?.there´s one pin that control power on/off ,is it good-solid data or is crazy . micro gets hot, have a correct 5Volt on its VDD pin. lot of cuestion that I hope helps you!!!
Jul 08, 2007 | Sony HMD A220 17" CRT Monitor
RCA 36V430T 36" TV Logo
139 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
