Question about Umax Astra 2000P Flatbed Scanner
Power input For whatever I do not have the power adapter cord to my 2000P scanner. I need to know the Power input that missing adapter supplied , that is, How many watts.
  • jcdc6543 Jan 09, 2009
    If you can't give me a simple answer to this simple question "what is the power rating of the power adapter to my Astra2000P /scanner?" Then you are no help to me. Do you want the scanner back?
    Take me off your FixYa, which is no help, and then answer my simple question which is 'WHAT IS THE POWER ADAPTER RATING FOR YOUR 2000P SCANNER/'
    I moved to a different location and somehow smiplaced and/or lost the
    original power adapter. I have several power adapters with output from
    3/ to 12v. I just need to know the power input of the original power
    adapter to prevent any damage to equipment. I will appreciate knowing
    that info.
    Dale Cook
    President:
  • 1,138 Answers
12 watts.
If you want to know more of the specifications in this flatbed scanner visit this link.
http://www.umax.com/support/knowledge/specifications.jsp?model=Astra+2000P
Posted on Aug 02, 2010
I lost the power cord of my Astra 2200. Can I use any input 12v cord?
I tried to find some information for you on this product but came up virtually empty handed.
I know this, it's a 12 volt power adapter.
You really should have more information than this to match up a power adapter, or you could burn out the unit.
My suggestion would be to take the entire unit into radioshack, and have them match it up for you, they have a universal power adapter system, very usefull.
Hopefully umax put the information on what power adapter is neccessary on the plastic housing next to the power adapter port, some companies do this.
Oct 28, 2010 | Umax Astra 2200 Flatbed Scanner
I picked up this monitor at a yard sale it says dc input?? is this the power supply? how do i hook up a ac cord?
If it says DC input and there are no other socket which has three prongs(this is for the AC input), all you need is an adapter, which you will plug to a wall socket and the other end would be plugged to the flat panel, it works like a transformer, just like any power supply, like for laptops, just try to find the correct voltage, 12v,16v or whatever is needed by the panel. Often you can find the voltage require on the panel itself, reading as POWER INPUT, xx volts or Power requirement.
Thank you for using Fixya.com
Oct 27, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Where do I get a new power cord for the HP 3970 which has been in storage for a while, but I want to begin using it agains, and can't locate the power cord. HP has discontinued this model and nothing on...
The correct part number for just the "brick style" power module (AC Adapter) for an HP Scanjet 3970 is L1970-80003. It is a specific 12V DC 2 Amp module. Today it can be purchased for $18.06 plus shipping from the HP Parts Store. However, if you are looking for just the power cord to your scanner's AC adapter, this brick style power module AC adapter does require a separate standard C13 detachable power cord to the specifications of your area, for instance, in the USA the power cord to connect the scanner to the power module AC adapter is part number 8120-6260, and it is a common power cord for monitors and computers. I learned all this because I had a scanner error message when I tried to use a different power module on the HP Scanjet 3970 when I lost the power cord to the original module. I hope this info helps somebody else, too.
May 24, 2010 | HP ScanJet 3970 Flatbed Scanner
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Missing power cord
buy a new power adapter with an input of 200-240v 50/60Hz 0.4A and an outout of +12V----1.25A.
Feb 23, 2009 | Genius ColorPage Vivid Pro Flatbed Scanner
Umax Astra 2000P Power Supply
You can use any over the counter 12 volt power supply from a DIY or computer shop, just make sure the tip of the
plug is switched to + and the ring is negitive
also that the power supply is rated at about 18
watts or higher
Jul 31, 2008 | Umax Astra 2000P Flatbed Scanner
Power supply for a 5500C
Delta Electronics
AC Adapter model ADP-36XB REV. B
Input:AC 100V-120V~850mA 50/60Hz
Output: 24V 1500mA LPS (Center positive)
Made in Thailand
Jul 02, 2008 | HP Scanjet 5500c Flatbed Scanner
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
Power cable missing
Your best bet would be to try ebay or contact Umax Directly.
Here is a link to their website:
http://umax.com/index.jsp?worldwide=usa
Good luck. If you found this solution helpful please rate this.
Thanks - Tech101
Feb 24, 2008 | Umax Astra 2000P Flatbed Scanner
Umax Astra 2000P Flatbed Scanner Logo
108 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
