Emachine windows xp welcome menu comes up and then black screen and we have sound but no picture changed monitors still does the same thing.never been used for internet
  • Andrew Podner May 11, 2010
    have you tried to boot in safe mode?
  • 53 Answers
Puddycat_196,
Did you just performed a clean installation to your system? Or maybe you just replace a new video card? The blank screen normally caused because of the resolution setting which is too high for the screen to support, or maybe the frequency setting, or you have incompatible video driver.
You can determine this problem by boot into your windows in VGA mode. What you have to do in order to boot into the VGA mode will be, press "F8" on your keyboard will you switch on your computer, you might need to press a few times, until you see the Boot Menu.
Choose "Boot with VGA Mode". More information about Advance Boot Menu will be available here
http://www.pcstats.com/articleview.cfm?articleid=1643&page=2
Once you successfully boot into windows in VGA mode, you can now adjust your display properties. Try to adjust from the lower range, like 800 x 600, and the frequency with the recommended one matched your Display Unit.
Good luck trying.
Posted on Jan 09, 2009
Wont boot/ says auto config over and over
Then use Recovery Console:
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
After restarting windows use a system utility software like RegInOut.
Dec 28, 2011 | E-Machines eMachines Desktop PC
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
The display screen got smaller.How can I bring it back to normal size?
You have to change the resolution of the screen.
Right click on the desktop, not on an icon- Properties- settings- at the "Screen Resolution" box increase the value.
7fb4f63.jpg This picture is for Windows Xp.
The following is for Windows Vista:
28993d7.jpg Select display settings and a window almost the same will appear. Again increase the value.
If you need further assistance, just post a comment.
Mar 29, 2010 | E-Machines eMachines Monitor E15T4
My laptop fell off the couch and landed on a back corner of the laptop. Immediately checked and had boot up sounds but no display. Was told to try external monitor. Got the vaio logo and the blinking...
This sounds like a resolution problem.
Can you move the windows messenger out of the way so you are looking at the Desktop screen (usual screen which has icons on it which is the first thing which appears after it has gone past the welcome screen)
On the desktop screen right click on a clear bit of space and try and change the resolution.
Failing this if you have an alternate monitor or LCD TV with VGA monitor input try use your TV and by outputting to your TV you will probably have enough of the screen displayed to copy what you need.
If all of the above fails. Best thing to do is to take your laptop Hard Disk Drive out of the computer and slave it into another computer or laptop to copy your documents / pictures etc as you clearly stated your not interested in reparing it. If your not sure how to do this then please come back to me
Sep 07, 2009 | Sony VAIO GRT170 Notebook
Green display on boot up Please help
Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
Jul 03, 2009 | Computers & Internet
Monitor screen turns off almost immediately
Do you connect all monitor wires on ... Do you got with screen or computer some MSI thing... the monitor blue wire must connect that thing then that MSI or whatever must connect to computer
Mar 08, 2009 | ViewSonic Computers & Internet
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
