Question about Western Digital Caviar WD800JB Special Edition 80 GB Hard Drive
Disk Read Error, nothing fixes it. Even when putting it into known working pc it fails.
  • Justin Goldberg Jan 09, 2009
    Thanks. mike1989. Slaving it and copying worked. But on the new disk I get a disk read error.
  • Justin Goldberg Jan 12, 2009
    Solution: Because PartitionMagic gave me error #108 (Partition doesn't end at end of cylinder) I resized the partition with Acronis Disk Director so each partition empty, unpartitioned space after each one.
  • 47 Answers
Sounds like a bad read head.. inside the hard disk.. you are better off to replace the product.
Posted on Jan 09, 2009
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool: or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
Disk read error occurred on hp mini 110-3135
Sounds like your disk drive has a problem. Now is the time when you need a CD drive to fix it or attempt to fix it by running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 11, 2012 | Computers & Internet
I had a similar issue and I could not fix it even after several attempts. I called
The Best Pc Doctor Team and they fixed it for me.I happened to know about them on
the internet.Their support was wonderful.I am including their contact details here.
877 407 9229(Toll free)
Oct 04, 2011 | Acer Aspire T135 PC Desktop
My xbox 360, Reads To play this disc put in xbox 360 console! How can i fix it?
I recommend clearing your system cache. To do this go to My Xbox > System Settings > Memory, highlight your storage disk, press Y and select "clear cache." Try to run the disk again. If the Xbox is still failing to properly read the disk I suggest bringing it to a gaming store near you and have them put a new drive in it. This is most definitely a hardware error, and has nothing to do with your disks.
Jul 01, 2011 | Microsoft Xbox 360 Console
I am getting an error message that says a SMART error has occurred and my hard disk will fail. When I press more information it says SAMSUNG HM250HI has failed and may crash at anytime. Disk defragment...
SMART is the hardware monitoring system that is put inside every hard disk. If it reports that the disk has failed then it has really failed - there is nothing left to do, copy (and nothing else or it will completely die faster) what you still can from it and junk it.
Get Avast.
Jan 22, 2011 | Samsung HM250HI 250 GB SATA Hard Drive
Dell XPS/Dimension and BLUE SCREEN OF Death!!
have you tried changing your hard disk drive? if not, try to change your hard disk drive. then start installing new windows.
Mar 24, 2010 | Dell Dimension XPS Gen 4 PC Desktop
I keep getting a blue screen. Put in my Back up
That blue screen you get is known to be the BSOD (Blue Screen Of Death) and is also known as the Blue Screen Error. The BSOD is caused by a device driver or chages in drivers or may even be a virus. Try obtaining a Windows reinstallation disk and reinstall windows. Keep trying your backup disk and look on the internet on how to use backup disks.
Good Luck!!
Hope i helped.
Nov 05, 2009 | Acer TravelMate 4200 Notebook
Light_On dvdrw SHW-160p6s working properly but doesn't read anyth
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
Hope this helps FixYa,
Jul 15, 2009 | Lite On Beige&Black16X Double Layer DVD RW...
Iomega zip drive Z100ATAPI returns error message: "Insert Disk into drive H:" even though there is a disk in it. It is recognized by the system and Device Manager in Windwos XP says the drive is...
Just because the device manager says the drive is working fine doesn't mean it is. If it won't recognize the ZIP disk, either the disk itself is bad or the zip drive is bad. I would try another zip disk and see if it will read a known good zip disk.
Nov 07, 2008 | Computers & Internet
D Drive / E Drive
try to cange cable if not buy new unit 20 bucks pop in easy they fail often thx nick
Feb 04, 2008 | Maxtor Hard Drive
Western Digital Caviar WD800JB Special Edition 80 GB Hard Drive Logo
135 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
