Question about Kenmore 46462 Front Load Washer
Kenmore Elite Fronloader Water Problem
Hi, My Kenmore Elite Smartwash he3 is having some drain/leak issues... I can't tell yet which is the actual problem. The washer is working fine, it's just that sometimes after it's done washing and we take the cleaned clothes out of the washer, there is a small puddle of water in the drum. I thought originally that there might be a clog in the filter or drain hose... not the case! When I opened the filter assembly, all the water from the drum drained out (of course). I did this before I went to work this morning. When I got home, there was another puddle and I noticed water dripping (very slowly) from the interior (where the water fills during the cycle). I ran a test cycle to make sure there wasn't a pump problem (there wasn't) and as soon as it was done, I turned off the water. It has been an hour since then and there's no sign of water. Where's the leak coming from? Can I access it? Is it something else? Thanks in advance for any help/advice you can offer! Sincerely, StratDude
  • Aaron Stratton Jun 03, 2007
    Thanks so much! Any advice on how to trace the inlet water hose? I'm assuming that should be approached from the back of the machine? Just want to make sure I'm going the right way.
    Thanks again!
    StratDude
  • Aaron Stratton Jun 04, 2007
    24 seven,
    Thanks so much! I'm on it!
    StratDude
  • 883 Answers
The water inlet solenoid valve has debris stuck inside of it, thereby not allowing complete "off" mode. best to remove it and clean the water path thoroughly. valve is found by tracing the inlet water hose.
Posted on Jun 03, 2007
  • Marty marty Jun 03, 2007
    yes, it should lead into a garden hose type of connector into the valve. I have disassembled valves completely and cleaned them and re-assembled w/out problems.
Why does my Kenmore Elite HE3 fill with water when it's off
The water valves are leaking usually from grit in the seat of the valve. They are a pair and can be easily replaced.
Aug 03, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
My HE3 kenmore elite quiet pak2 will not empty out water and spin
This due to the drain pump either being clogged or having a broken pump rotor. You can access the pump to check this by removing the bottom front panel by removing the 3 screws under the panel. You will need some towels bacause you will have A LOT of water come rushing out when you unscrew the drain pump cleanout. If this cleanout is clogged, remove the obstruction and test the washer, if there is no clogg you will need a new drain pump, this part can be ordered at, http://www.reliableparts.com/ by using your model number to lacate the pump. It is very easy to replace, just be sure to disconnect the power to the washer first =)
Please rate mt solution if it was helpful to you.
Thanks, Repairman45
Dec 15, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Elite He3 washer leaks horribly out the door.
the door could be bent out of alignent but its just as likley to be the rubber door seal,, and that is no easy job to change but its not impossible if i were you i would play it safe and have the repair man look at it,,,
saves all the greef from the wife if it gos wrong on you
Oct 26, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 46462 Front Load Washer Logo
297 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
