Question about GE JVM1441 Microwave Oven
GE JVM1440BD Microwave hood lights don't work
I have a GE JVM1440BD range hood microwave oven.
I was changing the range hood bulb (without unplugging, bad idea I know that now) and now I have no hood lights at all.
When I press the light button once I hear a beep but no relay click.
On the second press, I get a beep AND I hear the relay click.
The third press I also hear the relay.
Could it be that the "night light" relay is fried.
I assume it could be used for both night and bright hood light.
Also any ideas on where to get this relay? the part number is:
CS11-24SH
I figure it's worth a shot replacing it before replacing the board.
Thanks
  • 3 more comments
  • mjdupre Jan 09, 2009
    I meant the "bright light" relay, as that should be the first that in engaged.
    I don't see any visible damage to the circuit board tracings.
    I'm considering swapping the relays, I'm assuming that the "night light" relay is good, as I hear it click on the second push of the light button. I assume the second relay reduces the brightness by dropping the voltage to the light by adding a resistor to the circuit (or something like that, been a long time since my EE days).
    I'm assuming that both relays are only needed for the "night lite" mode. If this works, I'll order a new relay.
  • mjdupre Jan 10, 2009
    Swapped the relays and the lights now work (in high beam mode anyway). I've ordered the replacement relay and will replace when it arrives.
    Thanks, I'll check the diode when I get the new relay.
    Right now I'm just glad to have the lights working again, never really used the "night lite" anyway.
  • mjdupre Jan 21, 2009
    It seems to me that adding an inline fuse on the wire to the light bulbs would eliminate this problem, or at least protect the circuit board.
    of course this would have run up the cost per unit by at lest 50 cents Any thoughts on this, there seems to be plenty of room.
    Anyone point me to the correct wire and suggest the amperage for the fuse ?
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
  • William Miller
    William Miller Jan 10, 2009
    Also look for and check the "dimming diode", a black diode usually located between the light relay and the connector.
    (Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
    If it is shorted, you will have bright lights in both the bright and dim settings.
    Replacement rectifier diode is not critical and can be any of these: 1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125.
  • William Miller
    William Miller Jan 23, 2009
    I don't put fuses in them, but when I do the repair, I use 30AWG wire (wire wrapping wire) because its current carrying capacity is about 1 amp.
    If I didn't have wire wrapping wire, I'd use a single strand from an old lamp cord.
    You want your wire to be small enough to just carry the current and if there is a short, you want it to blow open well before the relay or other traces on the board do.
    If you're using a fuse, the wire size is not so critical. Make it big enough so it won't snap from handling. Wire from a "wall wart" ac adapter cord, for instance.
    Here's the formula to determine fuse size:
    watts / voltage = current
    If you have two 20 watt bulbs, that's 40W.
    Your line voltage is of course 120VAC.
    So 40W/120V = .33A
    Then we "derate" the fuse upward to somewhere between 0.5A and 1A to account for lamp turn-on surges.
    There you are.
Where did you get the replacement relay cs11-24sh. I have the same problom and also have traced it back to e relay but can't find any where online to buy a replacement one.
Posted on Mar 13, 2010
  • Anonymous Jul 06, 2010
    Where did you get the replacement relay?
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
Jan 24, 2014 | Microwave Ovens
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE Microwave model JVM1440BD operates but does not heat
On most occasions, it is magnetron. If you on your oven and hear an humming noise, that usually confirms magnetron problem.
You could see how to test magnetron
http://www.gallawa.com/microtech/mag_test.html
Let me know, once you test this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 11, 2011 | GE JVM1410 Microwave Oven
The bulb that is under the microwave that shines on the stove top is missing so I need to know what type of bulb to buy to replcae it.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Cooktop light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
So be sure to unplug the oven before removing or installing bulbs.
We see (and repair) this a lot. If yours needs repair, at our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore over range microwave oven / no power at all
Unfortunately, there is a good chance that when the bulb shorted out, it damaged the control board. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. The relays for the fan and the lights are part of the board. The power should always be disconnected when these bulbs are replaced or the board will be damaged. We would have an appliance repair person take a look to see what the deal is with the microwave.
Go here for Kenmore Microwave Parts: http://www.repairclinic.com/Kenmore-Microwave-Parts
www.RepairClinic.com
Feb 05, 2009 | Kenmore 62622 Microwave Oven
GE Spacemaker Microwave (JVM1630BH003) hood light locked on
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
If you or a friend decide to look into it further, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Microwave Ovens
GE JVM1651 Microwave
The control circuit board needs to be removed and repaired. We routinely repair these from customers nationwide for $32.50. It sure beats the cost of a new board!
Sep 11, 2006 | GE JVM1651 Microwave Oven
GE JVM1441 Microwave Oven Logo
1,065 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
