Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer tub bearing
Model number GHW9250ML0, Part # 285983. Ineed to replace this part, I have the part. I need procedure for removal and install. Thank you. Kyle
  • 640 Answers
Wow ,,that unit must sound like a jet ..this is a job,,i can talk you though but i cant tonight,,if you can wait i will help tommorow at 6 after work..if you need a little head startgo to cematters.com
Posted on Jan 09, 2009
Whirlpool duet front load washer banging Loudly during spin cycle as if off balance
More than likely the washer tub bearing is worn out, this happens due to seal failure and soapy water getting into the bearing, the soap is very corrosive and the bearing fails quickly, this in turn destroys the drum vibration dampers and makes it much worse. The cost to repair this is about $400
Feb 13, 2012 | Whirlpool GHW9150 Duet Washer
How do you remove the rear tub bearings on a whirlpool duet front loader. tub is out of washer but can't get shaft out
you have to buy the whole tub or basket,each part is around 230 dollars.the basket part number is W10250573 and it's around 215 dollars,this is the part with the shaft on it,the rear outer tub part number is 285984 and it's around 225 dollars.
Apr 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool Duet washer model GHW9150PW0 that began to thump during the spin cycle. I removed the front and it appears the inner tub is off-center or out-of-round. Further, it has worn off the...
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Hello, Model Number WFW8300SW00. We need a part number for the drum bearing? Would you be able to help us? Where can we get it? Thanks, Milka
Duet washer started getting louder and louder during the spin cycle. When I manually turned the basket I could feel that the bearings were shot. A quick search of the internet confirmed that this problem was no fluke. I found an illustrated parts breakdown of my washer online, and saw that Whirlpool only offers a replacement rear tub assembly, at a cost of $408. Needless to say, I was pissed off. I paid about $960 two years ago for this machine, and now it will require $6-700 in repairs. Unacceptable. So, having a mechanical background, I started to tear into the machine myself. I tore it all the way down to the rear tub half. I found what appeared to be the problem with my machine, hair. Hair worked its way to the bearing area, slowed unseated the seal, and then acted as a conduit for water to enter the bearing cavity. The seal itself actually looked fine. Yet the steel hub that the bearings are pressed into was badly corroded, as were the bearings, and even the driveshaft had corrosion on it. I pounded out the cheap factory bearings, cleaned up the bearing cavity and driveshaft, and replaced them with some higher quality Toyo's from my local bearings and drive store, P/N's 6206ZZC3 & 6205ZZC3. Unfortunately they didnt have a suitable replacement seal in stock. I didnt damage the factory one too badly upon removal, so I straightened it up with a couple of hammer taps, made sure it sealed nicely against the driveshaft, and reused it. The new bearings cost me $20. I made sure I sent a nastygram to Whirlpool, they offered me a replacement rear tub for 50% off, I told them to stick it. Hopefully I get at least 3 more years out of it, I've already started looking for my next machine, I'm likely going to buy a SpeedQueen. Anyways, if your tub bearings are shot and you have the will, they can be replaced yourself for a fraction of the cost of a factory rear tub half. My advice, take notes during disassembly, keep all the hardware from the different components you remove separated from one another. Dont be afraid to use permanent marker to write reminders directly on the components as theyll be hidden inside the reassembled washer when done. I did the repairs by myself, having a helper wouldve made things much easier. As for tools, I was shocked at how few I actually needed. A nut driver or torx apex, a 1/2" socket and rachet, some slip joint pliers, a wrench to remove the drive pulley, and a hammer and punch to remove/install the bearings.
Jun 10, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I require method to remove drum bearings on whirlpool washer WHI-AWM5125
You can't!!!!! You need to replace the rear tub half as the bearings are moulded into the rear tub.
The part number you require (Whirlpools own spares number) is 4812 418 18318 and this has an rrp of £109.76
Unfortunately you can't just bang out the bearings and replace them like the good old days
Mar 17, 2010 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Duet WFW9200SQ02 - high speed spin extremely loud!
I have the exact same washer, its also 2 years old, and this last week my bearings went bad too. I actually pulled my washer apart and replaced the stock el cheapo bearings with some better quality ones by Toyo. No, theyre not titanium, I'm a mechanic and I've never even seen titanium sealed bearings before. Not doubting they exist, but I highly doubt youll find them in any residential appliances regardless of make. Upon disassembly, I found what I believe is the issue with the seal, hair. Hair works its way to the drive shaft, slowly works its way into the seal, and then acts as a conduit for the water to enter the bearing cavity. Both sealed bearings eventually have thier grease forced out by water, and fail. This repair is time consuming, but it can save you a LOT of money. Whirlpool only sells a whole new rear tub, at a cost of $408 just for the part. I took it apart and found that the bearings are simply pressed into the steel hub on the rear tub half. I knocked them out, and a local bearings and drives shop had some replacements for me, for $20. I put it all back together, and its running fine. If you attempt this repair, make notes, and mark where everthing goes. You'll need to disassemble a substantial amount of the machine to get the tub assembly out. If youre not able to do the repairs yourself, I recommend buying a new washer, its just not worth spending $6-700 to have a shop do it.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool GHW9100LW1 washer stopped working
be sure that the tub is moving around with out the outer tub moving....could be a motor controller problem.....but heres the part#s tub assembly#8181912 youll want to replace the seal too. seal#8181673
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
I HAD THE SAME PROBLEM. I CALLED THE 800 NUMBER AND HAD WHIRLPOOL SEND ME ALL OF THE PARTS THAT WERE STILL UNDER THE EXTENDED WARRANTY THAT I PURCHASED. WHIRLPOOL SENT ME EVERY PART, INCLUDING THE STAINLESS TUB, THAT WAS STILL UNDER WARRANTY. I NOW HAVE REPLACED ALL INTERNAL PARTS EXCLUDING THE MOTOR.
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
Disassemble Whirlpool duet
Yes, but it is quite involved if you're up to the challenge. The following link explains the step-by-step details involved in removing the wash tub and spin basket:
http://www.fixya.com/support/r752855-replacing_rear_tub_bearing
I know this link is for replacing the rear tub bearing. The process is still the same, however, as it involves removing the entire tub shell assembly. There are no special tools required, but an electric screwdriver with socket attachments will make the process of separating the tub shell halves go much faster. I would also recommend that you order and replace the tub gasket if you are going to separate the tub halves. You can find a replacement gasket at searspartsdirect.com. Just type in your model number and look under the "Tub and Basket" heading for item number 10 (part #8181673). Other items to consider (but not mandatory) are the shocks for the tub (item number 23 - part #8182703). The shocks twist to release and they can sometimes break when you attempt to remove them. I hope you find this information helpful. If you have any questions, please let me know.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
268 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
