Goodman Dependable 92 blowign cold air only - no heat
Goodman Dependable 92 blowing cold air only
  • carl carpenter
    carl carpenter May 11, 2010
    is it gas or electric heat or is it a heat pump?
  • Dan Webster
    Dan Webster May 11, 2010
    Gas,electric ,or heatpump?
    Problem Solver:
  • 13 Answers
Blowing cold air on this furnace usualy caused by high limit trip, or flame roll out. the first one, (high limit) is from insf. air flow. (blocked filter,bad zone damper?
The second,(flame roll out) caused by bad heat exchanger,blocked vent.ect.
Posted on Jan 11, 2009
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
Dependable 92 ignitor
check continuity on hot surface igniter. no measurable ohms reading = bad igniter. also insure 120v getting to the igniter
Jan 26, 2014 | Goodman GMS90703BXA Heater
Home A/C is not blowing Cool air ice on hose
Not blowing at all or not blowing cold? Big difference.
Aug 31, 2013 | Goodman Heating & Cooling
Our goodman furnace igniter trys to kick in, but blows cold air. Gas company came checked furnace and told me goodman igniters tend to have this problem of them working fine and then blow cold air at...
it sound slike the presure switch is not working , if it is not lighting try jumping it out it may work some times you can fool it in to working
Feb 21, 2011 | Goodman Heating & Cooling
Yeah, im at a friends house who has a dependable 92. During the summer the power cord got cut by a weed wacker. An electrition came and repaired the power cord and the entire systems still wont work. I was...
Does the furnace still work or is everything out. I would check to see if the wires from furnace control board to contactor on a/c were put back together. They will be two very small wire from thermostat to a/c to pull conntactor in when a/c is called for.
Dec 13, 2010 | Goodman GMS90703BXA Heater
Air not coming out full force
Check the circuit breaker for the indoor unit. Also make sure the fan rotates freely by hand, then check the capacitor for the fan motor and replace it if bad. If the capacitor is good then check the fan motor windings to see if the fan is bad.
Jul 20, 2010 | Goodman Heating & Cooling
Changed the compacitor unit ran fine for half a day..then would not blow cold air..so i let it thaw overnight turned it back onit was fine..then after 5 hours..back to not blowing cold air..any...
if you let it thaw it sounds like your coil froze up
a frozen coil is usually due to lack of air flow (a dirty air filter or bad blower motor) if both of these are ok then you probably are low on refrigerant
i would suggest finding someone who specializes in goodman or someone who is certified to handle refrigerant to check your refrigerant pressures
Jul 29, 2009 | Goodman CKL24AR24 Air Conditioner
Cold air comes out but doesnt blow
The filter in a Goodman unit is in the Air Handler located at the bottom of the unit. Screw on either side take them loose and the filter pulls out. Now trun of fan first so the filter will come out easier. You may ahve other problems like stopped up coil or low on refrigerant. Russ
Jul 20, 2009 | Goodman CACF048B2A Air Conditioner
Heating & Cooling Logo
469 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
