Question about Danby DAC9003D Air Conditioner
When i set the electronic thermastat for this unit to shutt off, it does.......but then when temp gets higher then the preset temp i choose, it won't start up again.... i've also held the temp sensor wire in my hand while watching the digital read out go up to my warm hand and go down when putting it next to something cold thanx and would appreciate help
  • 105 Answers
There may be a starting delay built in, which will not allow restarting within 5 or 10 minutes. Other than that, the control unit may be faulty & require replacement.
Posted on Jul 15, 2007
E 1 error on display ?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 19, 2010 | Danby DAC9003D Air Conditioner
Power turns on but nothing else turns on, just the display screen. is there an easy fix ie fuse or something?
CHECK BREAKER AT MAIN BOX , SHUT OFF BREAKER ALL THE WAY OFF AND BACK ON. IF YOU DO NOT HAVE BLOWER WHEN YOU TURN FAN SWITCH TO ON THEN YOU STIIL HAVE NO POWER TO UNIT . GO TO OUT SIDE UNIT ON GROUND AND PULL OUT DISCONNECT FUSES AND TEST THEM OUT OF FUSE HOLDER LIKE AUTO FUSES. IF UNIT IS ON ROOF SHOULD HAVE FUSES UP ON ROOF IN 6  X4 GRAY BOX. SHUT OFF BREAKER FIRST BEFORE FUSE TEST. IF FUSES OK AND BREAKER OK THAN YOU MIGHT HAVE BLOWN TRANSFORMER.
Apr 21, 2010 | Danby DAC9003D Air Conditioner
How can you make your conditioner cool to 40 degrees
ACs are designed to cool down to about 68^F, don't think it has a chance of doing what you want w/o re-engineering the system which is not really an option.
Sep 26, 2009 | Danby DAC9003D Air Conditioner
Everstar MPM 08CR BB4
Set it so it doesn't have to work as hard (i.e. higher temp) and it will generate less water.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Code flasing!!
CLEAN YOUR FILTER THEN UNPLUG YOUR UNIT AND REPLUG IT AFTER ABOUT A MINUTE
Jul 10, 2008 | Danby DAC9003D Air Conditioner
Replacement hoses
what hoses
we are a authorized servicer for dandy and can get you any part you need that is available from the manufacture however air conditioners do not have hoses . if you need an external drain
hose you can get those at home depot or lowes
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE # 8
TAMPA FL 33624
OFFICE 813-908-2002
FAX # 813-908-5559
EMAIL customerservice@allbrandsappliancerepair.com
Jun 11, 2008 | Danby DAC9003D Air Conditioner
Room temperature has not changed since hooking up new portable a/c
This may sound dumb but ( 1) Do you have the warm air from the unit to the exterior of the space? If the condenser is in the space your putting the heat your trying to remove right back into the space. ( 2 ) There should be an air supply and an air return in the space only. With that there should be a temperature difference of 16 to 20 degrees between the supply and return. ( 3 )A 1 ton unit usually will cool approximately 400 square feet. ( 4 ) It may take a while to pull the space temp down due to pulling the heat and moisture from the ceiling, walls, and floor. This could take 6 hours or more the first time you use the system in a space.
May 18, 2008 | Danby Portable Air Conditioner
A/c will not work
Sounds like the control electronics are faulty. Replace control unit.
Jun 03, 2007 | Danby DAC9003D Air Conditioner
Danby DAC9003D Air Conditioner Logo
105 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
1STHVACMAN
Mike
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
