Question about Compaq Presario 5000 PC Desktop
WindowsXP Pro won't install
I am trying to reinstall WinXP because of very full hard drive. Do I need to reformat first? The new install cd that I have says it is damaged or not genuine..........
  • 47 Answers
Ok .. the very full hard drive does not necessarily require you to completley re-install just delete some files.. and you should be ok.. or remove some programs.. that take alot of disk space.. that should help you alot.. and a clean installation is often more trouble then it is worth...
Posted on Jan 09, 2009
  • 6,487 Answers
Yes you need first to reformat the drive so everything will be fine on your new operating system installation on that computer....
Laptop shutdown while reformatting and now unable to bootup
If it shutdown while reformatting the hard drive, restart from a installer CD/DVD and reformat the hard drive before installing the operating system.
Apr 23, 2014 | Computers & Internet
Windows installation setup says not find any hdd disk drives installed and says cannot continue
You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key. Check if BIOS still recognizes a hard drive. If not, you need to physically reconnect drive and try again.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
I lost my driver cd
You amy need to reinstall the drivers for the video card you should reformat the hard drive before you install anything if you did that try the drivers next. You may have to manually create an Icon for the wifi or try disabling and re-enabling it then again you may have to reinstall the drivers for it as well. If it came with OS install disks that installed them to begin with try running the install but choose the fix repair not the full install.
Nov 20, 2011 | Computers & Internet
I cannot start my computer after replacing motherboard and CPU. How do i install Windows onto the motherboard and how do I install eJiffy?
You forgot to sysprep the OS before removing the old board.
Put the drive back on the old board and CPU and let it boot up.
now sysprep the drive THEN re-install the new board and CPU
To sysprep the drive, do the following:
>There is a SYSPREP tool on the XP CD.
>You may need to extract files from the Windows XP CD, files are located at CD:\SUPPORT\TOOLS\ in a cab file called DEPLOY.CAB. The files are Sysprep.exe and Setupcl.exe.
>With the old motherboard still intact:
>You run sysprep and "RESEAL" Windows XP.
>Then you put the new board in, and it re-activates Windows XP and populates the device manager list.
>You do need to re-activate with the same key-code, and if you exhaust that number of activations, it will prompt you to call Microsoft and you get a new release key at no cost from them over the phone.
The basic problem here is that when windows goes to initialize the old hard disk controller, it loses the hard disk because the controller isn't the same.
It may also be crashing as it tries to initialize other hardware, but it needs that IDE or SATA (or SCSI) controller online even to get into safe mode!!
Good luck - sysprep works about 90% of the time, but if you run into problems, it can be a real bugger to untangle!
Feb 27, 2011 | Computers & Internet
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
I was reinstalling WindowsXP and hit the wrong drive to delete. I do not know if there is a way to get back all the data I had saved on the 250GB signiture mini. If not I will have to reformat it. Thank...
Try to make it a primary slave and use any partitioning software to undelete the partition. if it will not resolve your problem then you need to utilize a data recovery company or re-partion and re-format it.
Apr 26, 2009 | SimpleTech Signature Mini 250GB External...
T2240 cannot get the restore cd's to start
hello,
Yo need to configure in bios setup the first boot option. in the first boot press" F2 or delete" to go to bios setup.
in there select the CD ROM to boot first and then press "F10" to save and exit the setting.
reformatting and installing press windows the instruction is here;
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
may this help:
melnavz
PS: pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 04, 2008 | E-Machines T2240 PC Desktop
Reformat
Insert the winxp disk and boot from that, when prompted hit any key to boot from cd.
Win xp will start to install choose to delete the partition, confirm delete.
then press enter to install to that unallocated partition, choose format to NTFS.
Follow the prompts and it has formated the hard drive and will install XP.
Apr 30, 2008 | Dell Inspiron 8500 Notebook
STUCK IN WINDOWS XP INSTALLATION
you need restart your installation using your winxp cd. you can also go to your DOS mode by using your 3.5 floppy win2000 start up disk.
Jan 13, 2008 | Compaq Deskpro EN PC Desktop
Compaq Presario 5000 PC Desktop Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
