Question about Dryers
Timer and Shutoff
Here is my problem
When I have the dryer on a cycle (anyone) and the buzzer turned on when the cycle is done the buzzer wil not shut off. When I have the buzzer turned off when the cycle is done it will just go to the next cycle and never shut off.
I am not sure if the timmer switch is bad or if it is the buzzer start switch that is bad.
Can someone help please
    Scholar:
  • 47 Answers
Go for the timer. The timer is nothing but a bunch of contacts and some minor electronics. When the timer reaches the end of it's cycle, it closes a set of contacts which sends power to the buzzer, which could be bad, therefore continued buzzing. If the timer continues on to the next cycle either the electronics or contacts are shot. This is also age dependant on the dryer how the timer is built. You might go into price shock depending on model. This is not ruling out that if you have a buzzer on off switch might be bad, but I doubt it. Hope this helps. If you are unsure and are good at reading schematics and a meter, then you can be sure.
Posted on Jan 09, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Timer keeps running and beep won't stop
Timer died a noble death and needs replacement for proper operation.
Mar 11, 2015 | Dryers
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
My dryer will run for about 20 minutes and then shut itself off. I cannot turn it back on for at least an hour as the 'done' buzzer will buzz and the dryer will not turn back on. Does anyone have any...
If it happens during the auto-drying cycle, the moisture sensor could be faulty.
If it happens during the timed cycle, the operating thermostat may be faulty. A faulty operating thermostat can fail to turn the heaters off and allow the dryer to get too hot. When this happens, the high limit thermostat will turn off the machine. After it cools down, it will start again.
Apr 28, 2010 | Dryers
Done buzzer sounds
The cheapest solution is to continue leaving the door open. The timer is bad and hanging up at that particular point. They are typically 80 to 150 dollars to replace.
Mar 13, 2009 | Dryers
Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
Jan 24, 2009 | Whirlpool LEQ9858P Electric Dryer
Buzzer wont quit
have you tried to turn the knob slightly at end of cycle to see if it would shut off? try that if it does shut off then replace your timer
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Dryer buzzer
Depending on the model some have a separate buzzer you can disconnect and tape off the leads to it. If it is an electronic timer you can muffle the sound by taking a piece of electrical tape and covering the whole on the small black speaker attached to the timer.
Dec 18, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
187 people viewed this question
Top Dryers Experts
