Question about Whirlpool GS445LELS Gas Kitchen Range
Whirlpool oven won't ignite
Our gas range will not ignite. The oven had been cooking for 90 min and the flame seemed to go out about 10 min before time. After that, the oven would not start again. The igniters make a 'clicking' sound, but the flame never ignites. Any ideas? and is this something an amateur can fix? thanks for any help.
  • jen13 Apr 25, 2008
    the stovetop works fine...burners are all accounted for and able to be used. tried to turn on the oven for preheat and it just doesn't heat anymore. the range is 5 years old...never had this problem before. any ideas?
  • mobrien_ac Jan 25, 2009
    I was told that this is a problem with the thermostat. Is that correct?
Not a gas flow problem because i can manually light the burner just fine
Posted on Feb 20, 2010
  • 35 Answers
You do have a problem that needs to be attended to by a certified tech.you same to have a gas flow problem.maybe a valve problem.
Posted on Jun 30, 2007
2 Suggested Answers
  • 10865 Answers
SOURCE: Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
Posted on Apr 01, 2009
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool SF315PEK oven pilot seems Ok but gas in oven wil not light. How do I check that the gas is flowing or if it needs to be adjusted?
If what your experiencing with the oven is that the oven igniter glows but their is no flame,the cause of that is going to be because the igniter is weak and not getting hot enough to open the gas valve and allow the gas to flow. I know it seems improbable that since the igniter glows that it's the problem but i tell ya with 100 assiduity that's exactly what the problem is. Replacing the igniter will fix your oven.
GENE
Sep 14, 2011 | Whirlpool GS460 Gas Kitchen Range
Whirlpool range glow bar glows but no gas for flame mod sf315pekq1 ser vep1506815
iHello,
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
The part number for that igniter is 98005652 it could be purchased from your local appliance parts store or online at;
repairclinic.com
apdepot.com
searspartsdirect.com
apwagner.com
midwestapplianceparts.com
Gene
Aug 22, 2011 | Whirlpool SF315 Dual Fuel (Electric and...
Whirlpool gas oven won't heat to proper temp. Biscuits at 450 take an hour and 15 mins to cook and brown. What could it be?
The oven has a temperature sensor inside. The sensor tells the oven when to go on and off. It may need replacement. The sensor is protrudes from the back left wall of the inside of the oven. Make sure that it is fully plugged in and that it is not covered with any goop from the oven. The other things you can check is that nothing is obstruction the heat. That means NO foil or coverings on the bottom of the oven. It blocks the heat vents and can damage your oven. Underneath the floor of you oven, you will find the gas jets.The flame should come out blue and steady. It it is sputtering and orange, the little holes might be blocked. Clean carefully.
Nov 15, 2009 | Whirlpool GS460 Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Apr 01, 2009 | Whirlpool GW395 Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Oven takes way too long to heat
This advice is for GAS ovens with glow bar type igniters. This is how to determine if the igniter is bad. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance.
An igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad. An igniter should only take 30-90 seconds to ignite.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
For this solution, however, we’re going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
  1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
  2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
  3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
  4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
  5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
  6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
  7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
  8. Reconnect the wires using the recommendations mentioned in Step 5.
  9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
  10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models. I hope this information is helpful.
Mar 24, 2008 | Whirlpool SF315 Dual Fuel (Electric and...
Whirlpool GS445LELS Gas Kitchen Range Logo
1,484 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
