Sometimes different brands have more or less thread than others. The ones that are like the ones you took out should be fine. just take the others back to AZ.
You may have a differnt motor to the standard for your model the spark plugs that fit should be the right ones
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
Click
this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
HI, thanks for the help, but how can i know what type of motor i have?
thanks
thanks Philriden i will take your answer, but stil can you give me some TIP to find out what type of motor i have on my ford escort zx2 2000 please.
thanks
fn
i apresiatte your help now i know what type motor i have thank very much.
FN
