Question about Exercise & Fitness
At times belt hesitates
It happens more often on a slow speed. In a 20 minute period it did it twice.
  • 83 Answers
Sounds like either the belt is loose or the belt/deck need to be lubed.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
I need to know what the brand and model is to be able to tell you how to lube the treadmill.
Posted on Apr 30, 2010
When does your heart work the hardest
Work is often defined as how much volume or weight is carried, for how far in a given period of time. Examples: Move 1000 Lbs 10 feet in 10 minutes, Now move it 20 feet in 10 min - you've done twice the work. Or, 2000 lbs 10 feet in 10 minutes = twice the work. 1000 lbs, 10 feet in 5 minutes = twice the work.
So, a good measure for a heart would be how much blood is pumped in a period of time. The amount of blood in each beat doesn't really change, this distance is always the same, so how often it happens is a pretty good indicator. Simplified, you could say that the heart does the most work when it beats the fastest. Run for 130 beats per minute is 4 times the work of say, sleeping at 30 beats in a minute. Anything that raises yur heart rate to the highest would be the most work.
Apr 09, 2014 | Computers & Internet
Johnson 88SPL (1990) dies immediately upon accelerating after running at 1/2 speed for 1/2 hour
Are you sure your tanks and filters are clean? Sometimes its takes minutes or much longer periods of time for the trash to finally clog the filter. Im not sure how but after a period of time the trash can fall back away from the filter and then it runs just fine until this happens again. I spent two months trying to figure this out on a car. Look at your filter and whats in it. Its worth a try. Coils sometimes can heat up.
May 22, 2013 | Boating
I have a proform 740CS, it sometimes slows way down, if I step off it will sometimes speed up much faster than what it's set at, but then slows down again when I step back on. Other times, it remains...
Please LUBE very well the Walking Belt.
2) Inspect the drive belt motor, if is loose, Retight.
3) See if there loose wires for MOTOR.and retight.
4) The walking belt LIFT wiht your finger must be 2-3"
otherwise Readjust with the allen screw rear.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How To Lubricate Treadmill
Nov 22, 2017 | Proform 7.0 Crosstrainer Treadmill
Sometimes my M Eclipse won't go into gear
you have worn out teeth on your transmission or you need a new clutch disc.
Apr 04, 2009 | 2000 Mitsubishi Eclipse
No Hot Air
Check your coolant level. Service it if it is low. If it looks like it's at the proper level, check to make sure all air is bled out of the cooling system. There should be a bleeder fitting near the front of the engine, probably close to where the upper radiator hose connects. With the engine running, slowly open the bleeder to let air escape. When you see just coolant coming out, close it again. Do this every couple of minutes until no more air comes out.
Feb 25, 2009 | 2007 Dodge Charger Daytona R/T Sedan
Diagnosis needed for car repair
You problem seems to be an output speed sensor or some other type of sensor. As for the timing belt I would recomend replacing it before it does go bad.
Oct 28, 2008 | 2001 Acura 3.2TL
When I drive my Mazda 626 (97) in high way, at about 110 KM/Hour speed. Sometime the tachometer will suddenly go up and come down (e.g. go up to 4000 RPM or 5000 RPM from normal say 3000 RPM in one or two...
Does your Mazda have a standard trans (clutch), or automatic.
If it's automatic, the tranny might be slipping, and if it's a standard shift the clutch may be slipping. Does the actual driving speed (not engine rpm's) seem to stay the same when this happens? If you are still traveling at the same speed even though the engine speeds up, it's your tranny or clutch. I don't think the timing belt and tensioner have anything to do with this. countrycurt0
Aug 07, 2008 | 1994 Mazda 626
Exercise & Fitness Logo
280 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
