Question about SanDisk Sansa e260 MP3 Player
Earphone jack has a short.
After playing perfectly for months my player began to lose fidelity. I replaced the ear phones but it kept getting worse and now I can barely hear anything. But when I press the connector as hard as i can it sounds fine. My conclusion is that I have a short or loose connection in the earphone jack. Can anyone out there give me a clue as to what to do about this? Thanks...
  • 23 Answers
Take it apart resolder the connections. if the jack itself is bad see if you can find a new one. never worked on something that small myself, but should be fairly straighforward
Posted on Jun 06, 2007
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
No matter what set of head phones i plug into to my lyra rca mp3 player the left ear phone won't play anything
Most of this symptoms is a caused by bad solder joints on the earphone jack of the player. The unit must be take apart and re-solder the joints of the earphone jack. You need a pointed soldering iron to do this. If the symptoms still persist, the fault is in the audio circuitry. You must sent it in because this is not DIY, parts are too small and surface mounted.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 25, 2011 | Audio Players & Recorders
Apple Ipod 4th Generation is only playing music through left ear jack. I'm confident it is a earphone/jack replacement issue. The problem occured when someone yanked my ipod from me and the ear bud cord...
Well, yes you are right there is no other issue than earphone. you can purchase the earphone from the below link -
http://cgi.ebay.com/ORIGINAL-Apple-4Gen-Earphones-Headphones-for-All-iPod_W0QQitemZ260523098037QQcmdZViewItemQQimsxZ20091214?IMSfp=TL091214234010r19836
Good Luck!!
Thanks
Jan 06, 2010 | Audio Players & Recorders
My ear phones are broken and I cant find a replacement.
Hi Lyndsey Warr,
Earphone jacks are generally same for all brands on all devices (except a few) that can play music. Visit any store and pick up any good pair of headphones that fits into the jack. Of course, depending on the brand of your MP3 player, this might not be supported by the warranty, so if you're still within the warranty period, go to a service store and demand a replacement.
Oct 07, 2009 | Audio Players & Recorders
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
Ear phones Jack not working properly
It's possible that there is bad soldering to the jack's contacts.
Mar 26, 2017 | SanDisk Sansa E280 MP3 Player
Ear phone jack needs to be replaced
If you know anyone with soldering capability the pads on the headphone jack just need to be re-soldered. Mine did the same thing so I re-flowed the solder joint and now it works perfect.
-Brad
Dec 08, 2008 | Dell Pocket DJ MP3 Player
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
One earphone works
i had the same exact problem with mine. Reading around it seems to be a common problem with the Sansa line. I opened mine up and found that one of the solder points that holds the ear phone jack to the main board had come loose. I soldered it back and it works like a charm. Pretty easy too. If you have a soldering iron, just open it up and resolder the solder point that has broken off. You can read instructions for disassembly here: http://www.anythingbutipod.com/archives/2006/11/sandisk-sansa-c200-disassembled.php When you have it apart, looking at it from the side, with the jack to the right, the broken point should be the rear (closest to the circuitry) point. You will see a very small, not sure what to call it, chip on the board you have to solder a connection to. here is a diagram: http://i42.photobucket.com/albums/e321/fuzzygoat/sansa-c200-disassembley-8.jpg Hope this helps.
May 10, 2007 | SanDisk Sansa e250 MP3 Player
Problems with hole you place the ear phone
The ear phone jack is lose and your gonna need to or have someone resolder the audio jack inside the unit. if you know how to solder then it shouldnt be a big deal once you get the bugger apart. if your not good with a soldering iron, take the unit to an electronic repair shop and there shouldnt be much of a charge exept for minumum beance charge as this is not a major repair UNLESS the jack is ripped out of the PCboard or theres a flex cable connected to the ear jack as thats hard to fix correctly. Good Luck
May 20, 2006 | Samsung YP-T8 Digital Media Player
SanDisk Sansa e260 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
