Question about Frigidaire FDL25P1 Dehumidifier
Ice forming on the coils of my Crosley Conservator dehumidifier
The dehumidifier is in the basement. The daytime temp. is around 68 and the nighttime temp. around 60.
  • Frigidaire Master
  • 43,501 Answers
DehumidifiersIce forming on the coils of my Crosley Conservator - 2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on Jul 13, 2010
Crosley conservator dehumidifier will not capture humidity
Have you noticed it not running as often or not being noisy? Also have you tried to select a continuous drain setting if your unit has one?
Aug 14, 2012 | Crosley W.C. Woods DCW40S Electric...
When the dehumidifier runs it forms ice on the top of the unit and does not collect much water in the bottom.
The problem you described can be caused by 3 things:
1. The air intake filter is dirty or clogged and needs to be removed and cleaned.
2. The cooling coils are dirty and need to be cleaned. Turn the unit OFF & unplug it before attempting
to clean the coils with warm water and mild dish washing liquid. Then rinse and wipe dry. A light
coating of WD40 will help them stay clean.
3. The dehumidifier is being operated in a basement, where the air temperature at floor level is
below 65 degrees. When this happens dehumidifiers struggle at temps below 65 degrees F
unless it its a Low Temp model, designed for basement applications. Raising the unit up off
the floor onto a sturdy table or counter top, that can hold the weight of the unit, plus a full tank
of water, will generally resolve this problem.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 09, 2011 | LG LHD65EBL Dehumidifier
Does not generate water. The fan keeps on running. Forms ice on coils
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 06, 2010 | Danby DDR586R Dehumidifier
Have a wind chaser wdh running in my basement and it keeps icing
Dec 29, 2009 | Windchaser WDH928 Dehumidifier
Ice is forming on the coils of my Crosley Conservator. I used compressed air to blow out the grill and coils but it did not help.
most dehumidifiers will freeze up when it gets below 70 degrees. if where you are running it is below 70 degrees, then you need a different style. whirlpool makes a model specifically designed to run in colder climates. best buy or other that has whirlpool stuff.
Oct 27, 2009 | Frigidaire FDL25P1 Dehumidifier
Makinga chirping sound does not produce any condensate. Cleaned filter cannot remove front to access coils
MAKE SURE THERE IS NO ICE FORMING ON COILS IF U CAN SEE THEM. IF IN BASEMENT,
SURROUNDING TEMP MUST BE ABOVE APPROX 60 DEG. ALSO, TRY ADJUSTING THERMOSTAT
Jul 01, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier freezes up
Most dehumidifiers need warmer air to work properly. The temperature in a basement is usually 60 - 65F; too cool for standard models. You could buy a "basement" dehumidifier. They're designed to work at lower temperatures; some as low as 40 F. Costs are about the same as a standard dehumidifier; you just have to find it.
For a cheap fix, try this; it seems to be working for me.
Since the condensate coil (the one icing up) is cold, the air entering it is too cool and the condensate frosts up the coil. Additional condensate freezes to the frost and before you know it, you've got a block of ice. Since the air coming out of the front is very warm take a large piece of cardboard around 6' x 3') and form a V. Placed it in front of the dehumidifier so it channels some of the warm air back to the rear where it warms the moist air up before it hits the cooling fins. It's helped keep the ice down.
If you want something attractive, any screen that redirects some of the air back to the rear will work. Just leave the top open so it doesn't get too hot and the some of the drier air gets out into the room.
Jul 02, 2008 | GE AHG40LJ Dehumidifier
Parts
What is the model # from the sticker on the unit? I'll see if I can help.
Nov 03, 2007 | Dehumidifiers
Dehumidifiers Logo
500 people viewed this question
Top Frigidaire Dehumidifiers Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
buzz flewhart
buzz flewhart
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
