Question about Refrigerators
Bubbeling noises my tiny sized frigidaire makes bubbeling noises.drives me out of my mind.
    Guru:
  • 93 Answers
The noise that you are hearing is more than likely the freon in the sealed system. That noise is nothing to be alarmed about as far as the machine working properly. I get this complaint all the time and it turns out that there really isn't anything that can be done with the noise.
Try downloading the Top Freezer Frigidaire Service Manual. There is more about the noise and other noises that the fridges will make. It explains everything in great detail and things you can do to cut down on the noises themselves. You just have to narrow it down to exactly what is causing the noise.
Thanks
Posted on Jan 09, 2009
My 2001 740i bmw makes a ticking noise when idleing and if i turn on the air conditioner it gets louder
First off, have a good look at the engine and the a/c, try to find any leaked fluids or stains, could find the problem. If you hear a hissing or wheezing sound it may simply be a gasket or tiny hole in a hose / vacuum line. Open the hood while at idle, see if you can echo locate the noise ( with and without a/c.running) Be careful to avoid the belts and fans. If you still can't locate it. The only other thing that comes to mind is the belts themselves, if one is worn of frayed it can make a noise every time it passes over a pulley. One last thought, make sure you're using the right octane gas, too low and the engine will knock and / or tick. Hope some of that helps you, Grim
Aug 19, 2015 | BMW Cars & Trucks
My terios 2006 make tiny noise on front left shock while drive off road
check shock bushings and shock shaft play, the shaft that moves up and down inside the shock and is attached at the top mounting, as a problem with either can cause a noise.
Dec 17, 2014 | 2006 Daihatsu Terios 1.3
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
The lift for the tonearm doesn't go up high enough and lift off record
The Rega tonearm lift / lower platform has a 1.25mm hex socket, if my memory is still working. Some cheap allen key sets are around with a bunch of the tiny keys included..check the Pound Shop.
After you undo it..just needs a tiny nudge up, do a tiny nudge, tighten and check...repeat if more height needed- and mind your stylus.
May 26, 2012 | REGA RP1 Turntable
A kind of drilling noise from engine almost sounds like it is a diesel
hi
1 check engiene oil level.
2 check power steering oil level . when running lo it wil make that noise and wil make bubbels in the
steering oil fluid contener .
when filling use the recomended oil !!
greetings
joost
from the neterlands
Apr 10, 2011 | 2001 Volvo S40
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
When drum spins it makes alot of noise.
Check the main bearing and the pulley to make sure that they are both working properly if the bearing is bad it will make the drum bounce all over, if the pulley is bent it will make kind of a grinding noise along with things jumping everywhere
Feb 11, 2009 | Frigidaire FTF2140ES King Size Front-Load...
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Refrigerators Logo
663 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
