Question about Creative Labs ZEN V Plus MP3 Player
My player wont turn on. The computer reconizes it for a couple seconds but then the player shuts down. The play/pause button blinks but the olayer doesn't seem to be charging. The reset button is broken. When the player ties to turn on the reset menue shows but it is too quick to go away to reboot it.
  • 827 Answers
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon my player wont turn on. - battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
My rca m4304-A mp3 player says profiling requires 20mb free space shutting down and then when i try to hook it up to the computer it will not show that it is hooked to the computer and goes off
Restoring RCA M4304A Recorder Firmware
Symtom: recorder shows OPAL splash screen, then shows "profiling requires20mb of free space, shutting down" and then shuts down. Recorder cannot be accessed by windows or the RCA easyrip software.
Solution: Use the firmware update found here: http://www.voxxsupport.com/images/downloads/OPAL_066F_85A4_85A5_0_1140_SIG.EXE
This update needs to be ran on an xp computer running 32 bitOS. It was tested in a Win 7 64bitmachine and proven to not work.
Necessary steps taken to get the firmware to properlyrestore were as follows:
1. Hold in the power (menu) button for 10 seconds(the splash screen will show and it will give the error message, ignore it)
2. While still holding the power button, press theplay/pause button and hold down.
3. Release the power button while still holdingdown the play/pause button and wait 5 seconds.
4. While still holding the play/pause button plugin the usb cable to the recorder. Continue to hold the play/pause button foranother 5 seconds after plugging the cable in.
5. Release the play pause button then launch theEXE for the firmware update. Minimize the instruction screen so you can see thefull update screen.
6. Leave the format checkbox checked (check it ifit isn't checked) formatting is crucial to this working.
7. Once the status in the update window changesfrom initializing to ready click start to update the recorder. It will go through formatting, then updating.
8. Once the status shows complete disconnect therecorder and with any luck the recorder is usable again. The media files will obviously have to bereloaded, but the recording is functional at least.
Sep 21, 2010 | RCA M4204 MP3 Player
My ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
My tv won't turn on it clicks on then a second or
When it shuts down do any lights on the front light up red? If so its in prtective shutdown and you can get a two digit blink code by pressing in the menu and device buttons on the front panel. then counting the number of blink. It should blink a series of blinks and pause for the first digit then blink another series and pause for the second digit . then the process repeats. If a code blinks let me know what they were.
Nov 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
It wont Work :(
I would try to get into the recovery menu and see if you can run a clean up first (a clean up will not erase anything on the player).
To access the recovery menu
1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole underneath your player, beside the data/power connector. Keep on holding the Play/Pause button while you release the Reset button. The Rescue Mode screen will then appear.
4. After the recovery mode has started, release the Play/Pause button.
Again if you can get into this menu, try a clean up first to see if that resolves the problem. Clean up should be the first option in the menu.
Apr 08, 2009 | Creative Labs ZEN SLEEK MP3 Player
How do I shut off my zune!?!?
hi,
keep pressing the play button for 10seconds. it must shut off.
thanks you
Feb 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zen v plus won't turn on. The reset button is broken and it will have the play/ pause button blinking but it doesnt seem to be charging. The computer reconizes it for a couple seconds but then the...
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • If the battery is fully depleted, the charging icon may not be displayed.Cup the player in your hands to check that the blue power LED behindthe Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
Ifthe player does not indicate a charge, or will not power on after atleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to take advantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Creative Labs ZEN V Plus MP3 Player
Help turning on
Push the play/pause button and hold it down for a few seconds until the light turns on. Once the light is on and solid push it again. The light will blink while it is playing songs.
Jan 05, 2009 | Coby MP-200 MP3 Player
Ipod nano 2nd ed 1Gig
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Sep 18, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Help me please!!!!
probably a stupid question, but are you sure your music isn't copy right protected?
Jul 23, 2007 | Coby MP-C883 MP3 Player
IPOD Shuffle doesn't work at all
blinks green.
Jun 13, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Creative Labs ZEN V Plus MP3 Player Logo
71 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
