Question about Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot T2 moving in circle
Do the drive belts go on both sides of the Aquabot T2? How do I determine the drive side to place the belts on?
The T2 has one set of belts and a single drive motor. Since one side must be rotating to be moving in a circle, we can then assume that the motor and belts are not the issue here. The two halves of the brushes are connected by a mechanism that allows them to turn independently of the other half. They can rotate about 3 times before they “lock” and act as it were one (not split) brush. This “slippage” is how the cleaner turns. Make sure that they do lock by manually rotating one side. If not, you will need new brush/wheel tubes.
A parts diagram can be found here:
Aquabot Parts and Repair
Posted on Apr 25, 2009
My aquabot pool cleaner seems to run just fine, but no real suction, any have any ideas
Posted on Jun 05, 2009
  • 61 Answers
The t2 has 2 sets of drive belts and 2 motors...could be the belts, could be the motor
Posted on Apr 05, 2009
Replaced belts on drive side, no tension on other side though?
Refer this problem to Aquabot. It is possible that you were sent the wrong belts.
Nov 24, 2013 | Aquabot Turbo Classic
Troubleshoot aquabot turbo
bad pump motor possible bad drive motor also
May 09, 2013 | Aquabot Turbo T2 In - Ground Pool Cleaner
When i tried to change the belt, the outside plate cannot be fixed back, with great difficulty I did manage, but the T2 does not move now??
You probably have the drive belts and the tensioning pulleys installed wrong. If you look at the pulley it has one circumference larger than the other. The larger one aligns with the drive belt, pulley and wheel tube so when assembled, one side will have the large diameter "in", the other out, depending on where you located the belt itself. The tensioning pulley should be 'pushing' down on one side of the belt as it travels from the drive pulley out to the wheel tube.
If all these items are installed correctly, then inspect the teeth on the belt and mating surfaces as well as inspect the drive motor to ensure it is operating properly.
John
Aug 27, 2010 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot wont pump or move, intermmittent
Well either you have a jammed up motor, or a bad motor, or the Controller unit has faulted.
http://www.robotshop.ca/PDF/aquabot-turbo-t2-manual.pdf
Above is a manual, this should help you it has exploded diagrams to help. There seem to be many ways that it could get tangled up, or maybe the belt has come off, any way it's about time to A: Get a screwdriver, or B: Call a service man....
Jun 01, 2010 | Aquabot Aquaproducts Automatic Swimming...
My T2 stutters when is operates. Every 6-8 inches
The logic circuit located inside the motor has gone bad. Send out for repair...
Aug 26, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
How do I change the driving belts on the side?
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ will be a definite aid. Also, Aquaquality Pool Supply includes instructions with their replacement belt sets, or, if you are near Phoenix Az I will help you install your replacement drive belts, S. Christian dansker01@msn.com
Aug 03, 2009 | Aquabot In - Ground Robotic Pool Cleaner
Aquabot is pushing out water but will not move to clean the pool
I am not sure if this is the manual that you are looking for, or not, but just in case. If you following the link below it will take to you the T2 User's Guide, with the trouble shooting.
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/support-files/aquabot-turbo-t2-manual.pdf
According to the trouble shooting guide:
Pumps Water, but Does Not Move or Moves Slowly
1. Remove any foreign matter that may be obstructing Drive Tracks.
2. Check Drive Belts and Tracks. Make sure they have not slipped out of place and that they're not loose.
3. Observe Drive Pulley, if it is not moving contact Customer Service.
Jul 05, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
How do you change the rubber traction belts on the aquabot turbo t2.
First of all your cleaner is under warranty for 4 years or 300 cleaning cycles and is prorated. That being said, here is the schematic and contact info. http://www.aquabot.us/parts/aquabot.html
May 07, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot Turbo T2 In - Ground Pool Cleaner Logo
1,302 people viewed this question
Top Aquabot Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
