Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Dishwasher salt in Europe we use salt to our dishwashers. So my question is ... should I use salt in us dishwasher?
    Scholar:
  • 58 Answers
The only dishwashers so far in the us that have softeners are Miele and Fisher& Paykel . The Miele come standard and it's a option for the Fisher& Paykel. other then that i would not recomend you use salt in and other unit.
Posted on Jan 09, 2009
I poured a lot of salt in my dishwasher. What can i do?
Do you mean dishwasher salt?
Did you pour in free handed instead of using a funnel and it ran over? Just scoop out the extra.
Here is a link for dishwasher care and salt use.
Dishwasher Care tips for getting cleaner dishes from dishwashers
Nov 27, 2015 | Dishwashers
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
What kind of salt do I buy for use in the Danby DW?
Well Dishwasher salt is a particular grade of sodium chloride salt, and is used for recharging the built-in ion-exchange resins of the water softener in dishwashers that have a built-in water softener. The salt particles are larger than the size of table salt particles, and dissolves slowly enough that it will not clog the softener unit. This salt does not have added iodide salts, and it should have minimal amounts of iron and manganese salts. Some dishwasher detergents are marketed as not needing dishwasher salts. These detergents use higher levels of phosphate that increases the solubility of hard water ions. Never use table salt or detergent in the salt compartment of your dishwasher as this will damage your water softener unit. You can purchase the dishwasher salt from the below link -
http://www.mysupermarket.co.uk/grocery-categories/Dishwasher_Salt_In_Tesco.html
Good Luck!!
Thanks
Jan 07, 2010 | Danby 17 in. DDW1802W Designer Series...
Dishes are cloudy and covered with a film when done
Refill your SALT container with 1kg of dishwasher salt.
Salt reduces hardness in water -and increases cleaning efficiency. If you have a little furr build up in your kettle - you need salt in your dishwasher to work properly.
If you do use salt, it may be the salt reservoir is blocked with caked salt.
Oct 02, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Salt in the dishwasher
Run a full wash without any salt in it and then try I think you may have over filled the salt tank.
Thanks J
Jan 13, 2008 | Beko 24 in. D3421F Free-standing...
Dishwasher options
You should buy a dishwasher salt (don't put in cooking salt !!!!!) The dishwasher salt is a particular grade of crystalline sodium chloride intended for use in dishwashers.
Sep 16, 2007 | Maytag 24 in. MDB8751A Jetclean II...
Dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Aug 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
248 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
