Question about Evenflo ExerSaucer SmartSteps ABC Stroller
Can't locate the battery in the evenflo mega exersaucer to change
Where is the battery compartment located and how do I get it open and replace the battery? I have the circus model.
I have found a way to replace the batteries on the monkey truck.
First of all you have to consider if it is worth it. The monkey / banana truck takes three (3) LR44 batteries. I have looked and found these to cost $4.50 to $5.50 each.
If you choose to continue, please read all the way through the directions before continuing. Although my method does not require removing the decals, it does require damage to them.
1. Remove the truck from the Exersaucer. The base has four tabs that need to be slightly deflected to remove the base.
2. Turn the base over and remove the four screws holding the truck to the base. Remove the truck from the base.
3. Using a utility knife and following the seam in the plastic, make a slice down the center of the windshield decal and the back window decal.
4. Using a #1 Phillips head screwdriver, poke a hole in the decals of the front and rear driver's side windows. The hole is to be located halfway down the window, and an 1/8" (3mm) from the back or rear of the window respectively. In each hole, there is a Phillips head screw to be removed.
5. Remove the screw in each wheel on the driver's side.
6. Separate the two halves of the truck body, remove the center assembly. It may be stuck due to the glue on the side window decals. The yellow and red lights can be pushed out from the outside of the truck.
7. Locating the circuit board you can see the three batteries under retainers.
8. Remove the four screws holding the circuit board to the center assembly.
9. Bend up two tabs on the battery retainers and push the batteries out of the retainers.
10. Replace the batteries.
11. Reassemble in reverse order.
Posted on Feb 27, 2011
This is not an easy fix but it can be done. I have the circus model too and the carousel and the monkey car had stopped working. You need the following-1/2 hour free time, 1 miniature Phillips screwdriver with long neck, 4 LR44 button cell replacement batteries. Remove circus carousel from saucer top by squeezing tabs underneath. Locate and remove 4 very small screws [2 top/2 bottom]. The unit will seperate into 2 pieces and the drum will fall out. Look for brown circuit board with wires attached and gently slide this towards you and it will release from it's fitted slot. You will see 4 silver battery covers. The batteries are held under these by 4 teeth/tabs which must be gently lifted upwards with a knife in order to slide the battery out. Replace batteries, bend tabs back into place, slide circiut board back into slot, reposition small lights and drum and replace screws. Unfortunately, you cannot replace batteries in the monkey car without ripping off all the decals for the windshield in order to seperate it into 2 pieces...so I left that one alone.
Posted on Jan 23, 2009
Great information on the Exersaucer Monkey / Banana truck. I could not find those screw on the side windows until I saw this. I will add that you can use the AG13 button batteries as well, which are very cheap on Amazon.
Posted on Mar 23, 2014
    Problem Solver:
  • 11 Answers
Its under it u have to take the cover off and use a butter knife im 13 yrs oldlol!!!
Convertexersaucer to activity table
Here's an article along with photos and video on converting the Evenflo Exersaucer to the activity table: How to Convert the Evenflo Exersaucer into Stage 3
Apr 08, 2015 | Evenflo Exersaucer Triple Fun Active...
How to convert evenflo exersaucer
Here's a step-by-step article for converting the Evenflo Exersaucer. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
Mar 01, 2015 | Evenflo Exersaucer Triple Fun Active...
How do I convert exersaucer to activity table
Here's an article explaining how to covert the Evenflo exersaucer into the stage 3 activity table. How to Convert the Evenflo Exersaucer into Stage 3
Sep 01, 2014 | Evenflo Exersaucer Triple Fun Active...
I am needing an instruction manual for an Evenflo Exersaucer Triple Fun 25800496 08/06
hi
here is a page link to instruction download
near to bottom of the page
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
Oct 26, 2010 | Evenflo Exersaucer Triple Fun Active...
Need a replacement seat for a evenflo mega exersaucer
Contact Evenflo. Every time I did, they replaced the necessary part. It was a few years ago, but they were great then. Just give the website a try http://www.evenflo.com/category.aspx?id=19&fid=277
Aug 10, 2009 | Evenflo Toys
How do you change the batteries in the exersaucer circus tent?
on the back you should see a screw that is by its self try un screwing it and replaceing tyhe battery
Apr 03, 2009 | Evenflo ExerSaucer SmartSteps Active...
How to remove the seat cover on exersaucer
Hi, all the way around it are plastic bits sticking out and the seat cover is clipped onto the plastic bits, just lift them off one by one, all the way around. then when your done clip them back in again. hope this helps.
Mar 09, 2009 | Evenflo Toys
Need replacement part,a spring for Evenflo Exersaucer Mega Activi
Check thier website. You can enter in the model # and date of production (seat ring that the cloth attaches to). From there it'll show you all the available parts for purchase. You can also find/buy replacement or "switch a roo" toys from their website. I found this by googling "replacement parts for evenflo excersaucer".
I hope this helps!!!
Jan 04, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Changing batteries
Can you tell me what kind of activity center you have?
Jan 24, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Evenflo ExerSaucer SmartSteps ABC Stroller Logo
3,795 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
