Question about Lexmark X5470 All-In-One InkJet Printer
Computer is not reading usb from printer - Lexmark X5470 All-In-One InkJet Printer
  • 446 Answers
Ensure that your printer is on and check  other sources like other media devices, like USB stick or memory stick, if all else fail, it could be from your uSB ports that was having a prob
let me know
Posted on Jan 09, 2009
  • ariel santos
    ariel santos Jan 09, 2009
    pls go to ehow.com and  look for this article
    How to restrict USB access
    cheers
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
I am using lbp2900 printer with usb 001 port .but my printer couldn,t read the file from computer,they notefy{ The port is being used by another device]. how could i print properly?i had tried some file to...
TRY UNINSTALL AND REINSTALL PRINTER SOFTWARE. MAKE SURE YOU REBOOT IN BETWEEN. YOU MIGHT TRY ANOTHER USB PORT OR HAVE TO ADD A USB PCI PORT TO YOUR COMPUTER. GOOD LUCK.
Nov 18, 2012 | Canon LASER SHOT LBP-2900 Printer
My computer is reading "
please assure to numbering of PORT in setting properties printer driver with your plug USB port to laptop.
May 15, 2011 | Canon Office Equipment & Supplies
Hi I Have A Dell 968w Printer It Will Not Hook Up To My Network
hey if your printer has a usb cable thats another way you can connect it to your computer just download for the printer and if u have an usb on the back of the printer and it will read everything thats how i connected mine and it works
Mar 17, 2011 | Dell 968w Printer
I just bought a new HP photosmart C5580 with bluetooth wireless
Your printer can print wirelessly through bluetooth only.
note that your computer must be bluetooth capable also.
here's an instruction. Bluetooth Setup of Hp C5580
Apr 07, 2009 | HP Photosmart C5580 All-In-One InkJet...
All in One psc2210xi printer
Hello, the electrical spike may have also affected your pnter's USB port or worse. Does it copy/scan/fax ok? Try using the one of the USB ports from the back of your computer. USB printers do not like low speed, low power USB ports. Are you using a USB hub or plugging it into a usb port on your keyboard? I doubt the cable is bad, but check it carefully for any black marks on both ends. Have you tried other USB devices on this newly rebuilt computer? Good Luck!
Sep 23, 2008 | HP PSC 2210xi All-In-One InkJet Printer
Cable for hp photosmart 5180 three in one printer
Go to your local computer store or a Big W if you got one there and buy a standard USB printer cable. It has a small plug that plugs into your printer and a larger plug that plugs into your PC.
Sep 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Connecting my new PIXMA MX700 to my computer
Please read your owners manual.
It's very simple to connect a printer, and ever simpler to read the part of the manual that tells you how.
Perhaps you should get a friend to help you. If I say "Power Cord" and "USB Cable" will you know the difference? If not, I probably couldn't explain it to you through type.
If you think you could tell them apart, then do this:
1. Make sure you have a USB cable. Most printers don't come with a cable to connect to a computer. If yours did, you'll have two cables in the box. The USB and the Power cables.
If you don't have a USB cable, you'll have to go buy one.
2. Put the CD into your CD ROM drive, follow the instructions. When the computer tells you to, plug your USB cable into the back of the printer and the computer. Plug the power into the printer. Turn the printer ON.
The computer should detect the printer. Follow the instructions on the computer screen.
That should be all there is to it.
Dec 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Lexmark X5470 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
