Question about LG DLG5932S Gas Dryer
Gas dryer Problem
Fire turns on only for few seconds and then goes away.
  • kuldip2244 Jan 09, 2009
    Vents are clean, even I tried disconnecting from the vent. Flame sensor and thermistor get checked.
    New Friend:
  • 88 Answers
Check your dryer vent , check to make sure it is not full of lint or crushed. check the outside also make sure there is good air flow coming out.
Posted on Jan 09, 2009
Paragon symphony fire goes off after a while.
Have it serviced by a competent gas safe engineer for safety.
Nov 10, 2014 | Dryers
Why won't my gas dryer heat?
If your flame comes on for a few seconds & goes away,replace your solenoids. ($3.00)
If your flame doesn't come on at all, it could be the fuse(unsure of cost) Check the neg/pos lead with an OHM meter(multi meter), to see if there is continuity.
Let us know if this helps!
Jul 30, 2014 | Whirlpool LGB6300 Gas Dryer
My dryer turns on, will click then the fire ignites, but goes out after a few seconds, so it is not staying on, and it takes two and three cycles for my clothes to dry, is it the igniter?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer heats up but then cools down right away. I got the top off the cabinet, turned the breaker back on. start the dryer and you can see the heater turn red and give out heat for about 30 seconds and...
heatman101';
Apr 26, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Gas turns on ....link and ducts clean....gas only goes on for few seconds then turns off and few seconds later turns on again for short while...hummm
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Kenmore 67082 Electric Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag Neptune Gas Dryer MDG9700AWM fire comes on then shuts off after a few seconds. I have replaced the coils as well as the thermostat (part #20) if I just move the thermostat away from the burn tube...
TAKE THE FRONT OFF THE BLOWER WHEEL- THE METAL COVER ON THE BOTTOM LEFT CORNER- CHECK THE PLASTIC WHEEL INSIDE - THE CENTRES OF THE WHEEL WEAR OUT
ALSO CHECK THAT ANY EXHAUST DUCTING IS CLEAR
Jul 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Fire goes out
your fail safe has gone you can get a local appliance second hand shop should help you as they all have there own gas men to fix all gas stuff give it a try
Jan 05, 2008 | Maytag MER6772 Gemini Electric Kitchen...
LG DLG5932S Gas Dryer Logo
83 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
