Question about Cameras
My 6 year old cannon powerShot70 won't take pictures, when power up the view in the LCd is black with hazy streaks, shutter clicks and "picture" shows up in view mode the same as LCD screen view. Camera turns on and I can view prev pictures but cannot shot new ones. iused camera outside for about 45 minutes at 2 degrees celius, got great pics but when i tried it one day later got black LCD. HELP!
  • masters392 Jan 09, 2009
    I did not fully understand the solution I got ( see Below
    "Try first to reset the camera to its default settings from the menu and if doesn't fix the problem a firmware update will be a good idea in fixing the problem... "
    In my menu i have three options ,Camer,which covers Erd eye Af assit beam digtal zoom and review, all except review are set to "on" Review can be set as off or in seconds, the second menu item is Set up again several items that are on or off like soun, etc and the third menu option is my camera which deals with preferences, I can't find a place in the menu to reset to default settings AND I do not know what a FIRMWARE UPDATE is
    Help
    Yes, but can you recommend where i can take the camera for repair in the Vancouver British Columbia, Canada area?
    Thanks for your help
  • 2,071 Answers
This is hardware problem you need to bring your camera for service you can this link:
http://www.advancecamera.com/repair/
http://www.precisioncamera.com/
Hope it may help you;
Regards;
VOTIT
Posted on Jan 09, 2009
    Master:
  • 416 Answers
It looks like the camera CCD sensor is gone.
That is common malfunction for this model, espetially in a high humidity conditions. Check here for more information
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
But maybe you still eligible for refund as those models are under recall by canon
Good Luck
  • Cameras Master
  • 19,396 Answers
I don't think this is a setting problem.
Try removing the battery for few minutes, and doing a reset from camera menu but this does not look like a settings problem.
I think you have a faulty CCD sensor, or lens problem, I have just done another camera with the same problem. I repeat:
The array CCD sensor is the optic sensor that capture light to generate the image.
that is a defective camera ccd sensor, I have seen it many time the sensor for the camcorder is separate and it is working.
Look:
That is how it looks like, may be pink, gray, on black and white stains, more or less blurry, depending on how the array sensor is faulty.
If the pictures that you take come out the same , that is a faulty CCD sensor.The viefinder shows you what is detected by the CCD sensor, and passed to the logical board.
When the logical board is faulty it usually does not start, a problem of this kind is unfrequent.
If the picture comes out the same as the image only on camera , then it is a faulty sensor.
If instead you have static dark spots like blurred area, that do not follow the pictures while camera is moving that is a lens problem.
From description it looks like a bad CCD.
In either case the camera must be taken apart to replace the sensor, or reassemble lens.
  • Cameras Master
  • 6,487 Answers
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
No image on lcd for taking pictures. Lcd works fine to go through also to view old pictures. just black in camera mode. Tried shooting anyway and no picture. This happened once before and went away an hour...
Nov 05, 2009 | Canon PowerShot A620 Digital Camera
Problem with canon a420 digicam
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
LCD screen doen't display the view
So camera doesn't give live view to take picture? and you can view old / stored  pictures OK, is it?
If yes, then it is problem of CCD imager in Canon A80 and this part needs to be replaced.
Canon will repair your A80 free of cost as per announced scheme of CCD imager support.
Click Canon CCD Advisory to know how to get free repair facility.
Jan 07, 2009 | Canon PowerShot A80 Digital Camera
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
Sep 02, 2008 | Canon PowerShot A95 Digital Camera
There are quite a few of us with symilar problem, but the screen is not completely black: it has some purple or pinkish color when facing light. Old pics and menu can still be viewed. I noticed 4 symilar threads on Canon A95 within the last 5 mins without any search, just looking at the top questions.
Aug 09, 2008 | Canon PowerShot A95 Digital Camera
Cannot see any picture in my view-finder or LCD
Sounds like a CCD issue, can yoou see menus and pre problem recorded pics on the memory cards but no live views That is a CCD issue, ala C-5050 CCD recall problem, identical symptoms.
Nov 16, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
