Question about Amana ABB1927DE Bottom Freezer Refrigerator
Veggies freeze up in the compartment meant for them
Also What is the lowest setting ,1 or 7
  • 2 more comments
  • jrrennie920 Jan 10, 2009
    Appreciate the help . As for the Veggie drawer , a salesman told Me that it is a sign that all the RADON was aboout gone . LOL . He should go to the top of the class !!!!!!!!!!!!!!
  • Louis Furnari Jan 20, 2009
    veggies on my amana freezing, have at lowest setting.
    any help??????
    hdrocks1@comcast.net
  • lgl3 Jan 26, 2009
    I have an Amana refrigerator about 10 yrs old. It's the one with the freezer at the bottom. My vegetable drawer - the one on the left - freezes my Vegetables. I tried playing with the temp, the regulator for Humidity..but it still does it. What can I do?
  • Anonymous Jan 27, 2009
    The left side bin freezes my veggies. I'm not fond of frozen lettuce.
1 is the warmest setting, 7 is the coldest.
No answer for your veggies freezing.
Posted on Jan 10, 2009
Can a clogged drain cause the veggies to freeze in the drawer
If you have a clogged drain, your evaporator coil may ice up, impeding air flow and thus making the food compartments being too warm. Why are you playing with the temp setting anyway?
Feb 17, 2015 | Refrigerators
My Maytag Dual Pro top freezer is running too cold.
freezer should be -15 and that is about 4-5 c on the knob
fridge should be around 4-5 C which is around +3 C
frost build up is from door opened too often , for too long or bad door seals
It is more prevalent when the ambient humidity is above 50% as it is the water vapour in the air condensing on the cold surfaces
Dec 13, 2017 | Refrigerators
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have set fridge at 46 degrees yet salad veggies still freeze in the compartments. How can I fix this?
Remove the bottom drawers and locate the vent small round hole. cover it with a piece of sturdy tape...problem solved.
Nov 03, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
356 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
