Question about Asko W640
Spin cycle trouble
When the maching is on the spinning cycle, (it spins at 1400 rpm) it sometimes makes a sound like a hose has come off somewhere in the maching, its a bit hard to describe, sort of sounds like a bit like an air hose, like something has come undone, and then the machine still spins but also makes a clicking sound until I turn it off, and the words - Wash Motor Fault - come up in the display panel, it does not happen every time I do a load, it happened approx 2 weeks ago and I turned everything off as I was finished then have been using it since then, everything seems to be ok but I noticed this morning that when the maching is in the washing cycle it seemed to be making a sort of scraping sound, the maching has just finished a complete cycle and nothing happened again....only the scraping sound when washing. Has anyone out there got access to an Asko W640 workshop manual anywhere that may be able to help me. Apart from this problem it has been a great maching. I would be very grateful if someone couldl help. Thankyou Stells
    Sergeant:
  • 236 Answers
Possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Posted on Jun 04, 2007
ASKO W6903 spin cycle not getting to speed
Again it could be the carbon brushes or a faulty motor tacho
hope this helps
Mar 09, 2013 | Washing Machines
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
My ge front loader will not spin. the door is
My front load washer will not spin or the drum will not turn on the wash or spin cycle.
Dec 13, 2009 | GE WBVH6240F Front Load Washer
Hi My Hotpoint WF540 1400 spin is stopping mid cycle and not draining, rinsing and spinning unless I stop the cycle and choose just rinse and spin. Any suggestions? sarah
Probably needs the filter cleaning.
Remove lower rear panel.
Remove large black hose onto drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump itself.
Please rate my solution.
Thanks.
Nov 16, 2009 | Washing Machines
Will not go onto final spin on its own
check drain hose lid switch ....plugged pump or drain hose last timer
Aug 14, 2009 | Hotpoint WMA48 Front Load Washer
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
229 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
